Rack mounting antenna RUTX50
I was wanting to rack mount my RUTX50 but space in the rack does not allow antenna placement.
Can I extend the antennas via an RF cable to a SMA passthrough connector on the rear of rack and then screw antennas straight into the back of the rack at the connector. Would this work and is there any considerations I should be making.
I have an RUTX50 in a rack and use a Teltonika 5G combo 7 in 1 (PR1KC640) and basically sit the antenna outside and on top of the rack, works fine. Note sure how much loss would be expected via RF cable/connectors and standard supplied screw on antenna? .
