Public IP Passthrough 2 gets wrong address when device is active
Good day
Continuing with the following task: Public IP Passthrough gets wrong address when device is active
I tried it with 2 minutes, unfortunately the downtime is between an average of 1 minute and a maximum of 2 minutes. That is far too long, can’t you set the lease time lower?
Regards Thomas
Try using UCI commands on CLI. You can do so by accessing CLI via 3rd party apps, or you can navigate to System > Maintenance > CLI on WebUI:
Login: root
Password: your admin password used to access the router
Enter following commands:
uci set network.mob1s1a1.leasetime=15s
uci commit
service network restart
Please let me know if it worked for you.
Lukas
hi lukas
I have noticed strange behavior and that in the original state.
Status>Network>LAN
The least time always counts from 1m:58s - 1m and then starts again at 1m:58s
I have now adjusted the parameters as described and the uci set dhcp.lan.leasetime=15s as well.
But nothing has changed under Status>Network>LAN.
Hello @tom
Yes, it appears that the lease time is capped at a minimum of 2 minutes, regardless of any changes made in the configuration files. I will investigate further, but I cannot guarantee that it will be possible to adjust this setting.
@LukasV When making your enquiries, please can you get a response as to when this behaviour in Passthrough and Bridge mode will be fixed.
This same subject is currently being talked about at RUTX50 - Passthrough, DHCP & (assumed) Firmware Issue - #9 by OffGridBeachBoy
Looking forward to a resolution date.
Mike
