Dear All,
I am trying to configure the serial port on a RUT955 so I can access it via the LAN. To do this, I configured the router as shown in the images.
To access the serial port over the LAN, I’m using the HyperTerminal application, where I enter the router’s LAN IP address and the port I created. However, when I do this, HyperTerminal tells me that the connection could not be established. The router’s firmware version is RUT9_R_00.07.06.21. What could be causing this?
Best Regard
Thank you for providing the configuration screenshots.
The IP filter in your screenshot currently lists the WireGuard interface. Please ensure that the selected interface matches the connection you intend to use and that the Allow IP field contains the permitted source IP address.
If you intend to connect through LAN, select the LAN interface. You may enter 0.0.0.0/0 in the Allow IP field to allow any IPv4 source address on that interface.
Save and apply the changes, then reconnect using the router’s IP address reachable through the selected interface and TCP port 2001.
For additional information please refer to the Serial OverIP guide:
T.
