Problems connecting IPsec after FW update on RUTX50
Hi
I have upgraded RUTX50 to firmware RUTX_R_00.07.12.3.
When i was verifying the IPsec tunnels all seemed OK but after 30 seconds the IPsec tunnel disconnects.
If i reboot the router the same thing happens again.
If i try to disable/enable the tunnel nothing happens.
We apologize for any inconvenience this issue may have caused.
Our developers are aware of the issue and are actively working on a resolution. The fix will be implemented in a future firmware update. Unfortunately, I don’t have an exact release date, but I will keep you informed if I receive any updates.
Thank you for your patience and understanding.
Then I will downgrade to the previous FW version for now.
