Probleme mit eSim beim RUT241
Die eSim hat auf meinem neuen Router seit dem Kauf im Juli 2025 bis September funktioniert. Dann habe ich im Routerprogramm auf dem Laptop ein erforderliches update gemacht. Dann funktionierte die eSim nicht mehr. Der WLAN-Shop 24 stellte damals fest, daß das Programm die IMSI -Nummer geändert hat in nur 9er: 99999999……Leider ist der Shop insolvent, so daß er mein Problem nicht mehr lösen konnte. Die Firmware-version ist RUT2M_R_00.07.17.4.
Ich hoffe, daß Sie mir helfen können.
Mit freundlichen Grüßen Dietmar Batz
I kindly ask you to continue the communication in English, so we can understand each other better and other users can also follow and help if needed.
Could you please log in to the WebUI, navigate to Status → Network → Mobile, and check if the IMSI is displayed as 999999... on that page?
Yes See Appendix
Could you kindly share a screenshot of the System → Firmware → Update firmware page?
Hello, here the Screenshot.
Regards Dietmar
Thank you for providing the screenshots. For further troubleshooting, we will need some additional sensitive information. I have sent a form to the email address you are registered with on the community forum. Once you fill out the form, I will contact you privately.
Please use ticket ID “16153” when completing the form.
Hello, I’m send you also the Kernel-Protocol.
I have also the system-protocol.
Do you need?
Regards Dietmar
We’ll need to collect the mobile logs to investigate this further. I’ll send you an email shortly with all the details.
Hello
I have sent all Informations to your Support-Adress but I doesn’t get any answer the last 2 weeks.
What happens?
Regards Dietmar
Our last email reply to you was sent on November 7th. I have just resent it.
Could you please let me know if you have received it?
At 07.11.25, 12:39 write Dietmar Batz <dietmar.batz@gmx.de>:
Hello, yes I have done and than I copy
modem_logger -c /tmp/QMI_AT_OTA_UIM_APDU.cfg -s 9000
and than come
The system cannot find the specified file
“Modem_logger”
  • see attachment.
Regards
Dietmar Batz
Could we please continue our communication via email?
When replying, please make sure to click “Reply” directly on our email. Otherwise, your response may not reach us.
Thank you!
Hello, is this the correct way?
Regards Dietmar Batz
….or is this the correct way?
Best regards Dietmar Batz
Unfortunately, we still have not received your email.
Could you please confirm if you are clicking the “Reply” button when responding to our message? This is important, as using any other method may prevent your email from reaching us.
Thank you!
I get a email from you and there is a button - visit topic to respond.
Than open another site and there I write my answer and use the blue - reply- button.
I hope this is the correct way.
Regards Dietmar
You should receive an email from a HubSpot address regarding collecting logs — not from the community forum. I have sent the request for modem logs to your email. Please open that specific HubSpot email and use the “Reply” button directly in that message to respond.
Hello, I doesn’t get any email from a hubspot Adress.
At 1.12. I sent myself a email to this Adress
support@26113579.eu1.r.hubspot-inbox.com>
and wait also for an answer.
Sorry, but I doesn’t know what I can do.
Sorry, I was wrong. I get an email and answer at 1.12. to the Adress before but I get no answer till today.
Regards Dietmar
