Problem restarting the RUT200 device
Good evening, I am writing because I encountered a problem with my RUT200 router.
Introduction: I have configured the WAN port in bridge mode with the Wifi network which in turn is connected in Wifi Client mode. I also inserted a Port Forwarding and once set everything works correctly.
Unfortunately, however, when I restart or turn the device off and on again, I can no longer reach what I connected to the WAN port and I am unable to access the WEBUI via WIFI. Everything seems to reset when I go into the topology menu and press the SCAN button. After a few seconds everything goes back to working correctly, until the next reboot where the problem returns.
What could it be?
Thanks!
Andrea from Italy.
I would like to review a troubleshoot file. I have sent you a form to fill out. Once completed, I will contact you privately regarding this. For the ticket ID, please use “7730”.
Good morning, thank you for your kind reply.
I have already filled out and sent the form.
I await your kind feedback.
Thank you.
Andrea.
