I have had trouble with ensureing that all the requests set up in my modbus TCP client of wich I have 3 are sent to the server via the data to server configuration with the same rate. I have seen that the first request defined in the Modbus TCP client has the most number of sent data to the server and the ones that are defined after have smaler with the last one the smallest. I have my data sender set up whitout data filtering so it should send all the request with the same frequency?
