Dear Forum, can you please tell me if the RED washer provided with the PR1KCL25 antenna must be outside or inside the IP66 rated control panel. This is connected to RUT241 inside the panel.
Regards
Kaly.
Regards
Kaly.
Hello Kalyan1803,
Thank you for reaching out to us
Regarding your question about the PR1KCL25 antenna installation:
The antenna base is positioned on the outside of the panel
The red sealing washer is recommended to be placed on the outside, between the antenna base and the panel surface, to ensure proper sealing
The securing nut is tightened from the inside of the control panel
It is also recommended to apply additional sealing on the inside of the panel for extra protection
The red washer acts as a sealing gasket to prevent moisture from entering the enclosure and helps maintain the IP66 rating
Could you please confirm how the antenna will be mounted?
Please let me know if you need any further clarification.
Žilvinas
