Looking to set up the router RTU241 for remote BMS access.
Can I set up HTTP traffic port forwarding?
UDP Port: 47808.
Also looking to find the public IP address for BMS set up?
UDP Port: 47808.
Thank you for reaching out.
Yes, you can set up the required port forwarding on your RUT241 router by going to Network → Firewall → Port Forwards.
Could you please clarify if I understand your setup correctly? Are you aiming to forward requests from port 47808 on the WAN to port 80 (HTTP) on your BMS device, or in reverse?
The public IP address of your router can be found on the Network → WAN page, under the mob1s1a1 interface.
For more detailed information on configuring port forwarding, you may find this guide useful: Port Forwarding Setup.
Please let me know if you need further assistance.
I think i have to forward to 47808 on the BMS device
Thank you for the clarification.
In your case, the port forwarding setup should look similar, like in the example screenshot provided below:
Please replace “BMS IP address” with your BMS’s LAN IP.
Let me know if you have any further questions or need additional assistance.
This address changed from yesterday to today, I’m looking for the public IP address to be static to allow remote connection?
Please keep in mind not to share any private or sensitive information (such as public IP addresses, MAC addresses, passwords, etc.) on this public forum.
If you’re looking to have a static public IP address to enable consistent remote connections, then you should contact your ISP, as they are the ones who can provide this service.
