Pole Camera configuration VPN tunnel
I currently have four cameras mounted on poles, with each camera connected to a Teltonika RUTX50 router. Is it possible to configure all the cameras to use the same IP scheme (e.g., 192.1.1.1-192.1.1.5)? If so, how can I set this up? Additionally, each camera will have a public IP address provided via an AT&T SIM card.
I would like guidance on configuring these cameras to connect to my site through a VPN tunnel, where our Hikvision NVR is housed. What steps should I take to establish this connection securely.
If your RUTX50 device has the IP address 192.1.1.1, its LAN devices using DHCP (see documentation) will receive IP addresses within the same subnet (e.g., 192.1.1.2, 192.1.1.10, 192.1.1.100).
For guidance on configuring a VPN, please refer to this wiki page: RUTX50 VPN Configuration.
Feel free to reach out if you need any further assistance.
