Poe shedule on tsw202
Hello
is it possible to switch one poe off and on with a time table?
I will switch on poe out over night.
I would be happy about some advice.
To switch PoE on/off at a specific time each day, you can create a custom script and use a crontab to automate its execution at the desired time.
You can find the commands to change PoE in the following post: TSW202 - PoE wont switch off from CLI/SSH - #7 by Janmiguel.
For guidance on creating custom scripts, I recommend reviewing the following resources:
For setting up crontabs, please refer to this page:
If you have any further questions or need assistance, please feel free to reach out.
I believe that this could be done purely from WebUI by using Profile Scheduler https://wiki.teltonika-networks.com/view/TSW202_Administration#Profiles
Create two profiles one with poe enabled other with poe disabled and make them switch on desired schedule.
If you will be using this also make sure that switch’s “Date & Time” is correct and it has working NTP client (if switch has working gateway it probably has) because these device do not have real time clock.
