PLC access through RMS problem
Good afternoon,
I configured a VPN hub for accessing to a Siemens PLC through a RTU241 installed remotely. For the first 2 minutes the VPN access worked (I could ping the PLC address) but after that I can not access again. If I create again the VPN hub happens the same…
If I create a remote connection I can access to the PLC webserver, but thats all.
Any idea where is the problem?
Follow all the steps carefully shown in Teltonika’s video tutorial.
https://www.youtube.com/watch?v=dfAudZR2wPY
And especially make sure that LAN access is enabled for the specific client:
Good afternoon,
I followed the instructions according the video and it does not work. The funny thing is if I create a quick hub it works for some time but after it stops working and I need to create it again…
BR
Is your RUT241 running on the latest software version?
RUT241 Firmware Downloads - Teltonika Networks Wiki
Firmware RUT2M_R_00.07.09
This is good.
Can you one more time go back to factory defaults
RUT241 Device Recovery Options - Teltonika Networks Wiki
and make sure you’re running on IPv4 only and Auto APN afterwards
If you then carefully configure again according to the video it should work.
I personally did exactly the same yesterday and it’s working like a charm - using RUTX50’s though but also software 07.09.
