Hello everyone,
I’m considering using the RMS service but I have a question.
I have about 50 active devices and at the moment I need to monitor the following parameters in real time:
Cell ID
Connected band
RSRP
RSRQ
SINR
Is it possible to view all these devices in a grid with the parameters just mentioned?
In the first instance, can you advise what device/devices you use? And the product code for these devices so that we can check what modem it has. Product code can be found in WEBUI Status → System.
Good morning and thanks for the reply
the devices I use are:
RUT240
RUT360
RUTX12
RUTX14
I am already using the 30-day RMS service period on a RUT240. I noticed that the only thing missing is the connected band
I would also like to know if it is possible to have a history of the connected band to which it has been connected throughout the day
To assist efficiently I would need the product code for these devices as well, as without that information I am unable to know which mobile modem the device has, which is necessary information.
sorry I didn’t realize that this information was needed
The information of the device under test is as follows:
Product code: RUT24006XXXX
Modem Model: EC25-EC
FW version: EC25ECGAR06A14M1G_20.200.20.200
