We observed that on RutOS 7.20.1 (RUTX09), the WebUI HTTPS certificate (/etc/uhttpd.crt) remains auto-generated and cannot be replaced by an imported certificate, even when selected in the GUI.
Could you please confirm whether replacing the WebUI TLS certificate with a custom external certificate is supported on RutOS 7.x, or if this behavior is intentional?
Hello, @hboyault ,
Thank you for reaching out,
I am currently trying to reproduce the issue, I will let you know once I have more information and insights on this.
Warm regards,
I was able to successfully create and run a working OpenVPN instance with custom TLS certificates on firmware version 07.20. To help us investigate further, could you please provide more details about the issue you are encountering and outline the exact steps required to reproduce it?
I look forward to your reply.
