Over ip on rut955 router
Dear Expert
I have a RUT955 Router which include RS485 and RS232 port.
I need use Over IP function for it and Router work in TCP server Mode. The diagram is below picture
On the computer, I need to a soft/tool in order to create Virtual COM for Router.
Where Can I find this tool/soft?
Best
For this, you can use HW VSP3 application. There, you can create a Virtual COM port towards IP address of RUT955.
Then you can use the COM port on your PC to communicate with your PLC. This depends on your application. For testing, I would suggest using Hercules application where you can select your COM port created with HW VSP3 in the serial tab.
