I’d like to be able to schedule multiple periods a day when the Output pin is active. Looking through the Output Scheduler, it appears to only support one period a day. I tried configuring an Instance for each time period (8:00 to 8:15, 9:00 to 9:15, 10:00 to 10:15, etc.) but the OS would only allow one instance to be enabled at a time.
I recommend updating your device’s firmware, as the issue you are experiencing must have already been fixed in a firmware version newer than the one you have installed.
