Hello, I need to install the OTD500 on the mast of a sailboat.
A positon quite good to protect against rain etc is below the spreader, horizontally, at about 10 meters from the sea level.
How will be the performances with horizontal installation? They will be different compared to vertical installation?
Thank you for your question regarding the OTD500 installation on your sailboat mast.
To answer your main question: horizontal installation is absolutely fine, and the position you describe - below the spreaders at around 10 metres - is actually a smart choice. Here is what you should know:
Signal Performance
The OTD500’s internal antennas are omnidirectional, so orientation has minimal impact on RF performance. You may see very marginal differences in radiation pattern between horizontal and vertical mounting, but nothing significant in a real-world marine environment where signals arrive from all directions.
Weatherproofing
This is where orientation matters most in practice:
Ensure all cable entry points face downward, or seal them with marine-grade cable glands to prevent water ingress
The IP55 rating handles rain and spray well, but saltwater mist at mast height is a harsh environment - proper connector sealing is essential regardless of orientation
The below-spreader position also helps reduce direct UV exposure and wind-driven mechanical stress on the unit
Vibration & Fastening
Masts vibrate considerably under sail. Make sure the mounting bracket is fastened very securely using locking hardware to prevent anything from working loose over time.
In summary, your proposed installation position and horizontal orientation are both well suited for this deployment. The main focus should be on cable sealing and secure mechanical fastening rather than on orientation itself.
Please do not hesitate to reach out if you have any further questions.
