Opton to create Default Configuration gone in 7.09.1
I Just upgraded a RUTX10 from 7.08.3 → 7.09.1
In 7.08.3 and before there was an option in
System / Maintenance / Backup
to create a Default Configuration.
I believe this configuration would be the one used when setting Reset Button Configuration in
System / Administration / General User’s defaults configuration
(the one that is used when you hold the reset button for 6-11 seconds)
However in 7.09.1 the option to create default configuration has disappeared.
How do I now set this default configuration?
Thanks for reaching out!
You can find the page from the System > Maintenance > Backup section
You still can take the backup file and upload.
Caner
Thanks Caner for your response.
Yes, in fact I understand that I can still take backups
(and I do this regularly)
but that is not what I am asking.
Of course I create backup files.
Let me express the question differently:
** If I hold the Reset Button for 6-11 seconds
the system should be booted to the default configuration/
But now there is no Default Configuration.
So what will it reboot to in this situation? **
Thanks for providing detailed information!
Default configuration is still there. Below picture is from my router which is on 07.09.1 Firmware.
You can reach the page from the System > Administration > General on the WebUI.
If you can not see it, can you please share the screenshot of the page?
Caner
Carner
yes of course I can see it.
That is why I am asking
BUT the option to create a Default Configuration has now been REMOVED!!!
Please, return to my FIRST post:
HOW DO I NOW SET A DEFAULT CONFIGURATION???
thanks
mc
@Caner … I believe MC is referring to the UI option below, available on previous firmware versions
Thanks Mike, you are correct.
That option has disappeared in 7.09.1.
regards
mc
Default configuration replaced to the System > Maintenance > Reset Settings on the WebUI.
Caner
Thank you very much,
and extra thanks for your patience.
mc
