I followed the tutorial but the first configuration doesn’t work. I get error : “TLS Error: TLS handshake failed”. I’m using a RUTX11 as server and RUTX10 as client.
Could it be possible to update the wiki and add a server (RUTX) with client (windows) example, please ?
Thanks for your help.
The current latest article on OpenVPN configurations can be found here:
https://wiki.teltonika-networks.com/view/OpenVPN_configuration_examples_RUT_R_00.07
https://wiki.teltonika-networks.com/view/OpenVPN_client_on_Windows
If that does not help, could you provide a screenshot of your configuration (remove any sensitive details like public IP addresses )? Additionally, please verify that:
You are able to reach the RUTX11 from the RUTX10
Verify that the correct certificates were uploaded
Verify that time was synchronized on both routers
Make sure that the IP address assigned to the mob1sXa1 interface on the RUTX11 is not within these ranges:
10.0.0.0 - 10.255.255.255
172.16.0.0 - 172.32.255.255
192.168.0.0 - 192.168.255.255
100.64.0.0 - 100.127.255.255
system
Closed
February 7, 2024, 12:53pm
4
