Hi all,
Im running a OpenVPN server on a UniFi Dream Machine Pro but can´t get my RUT-950 to establish a working connection.
The UniFi is on a fibre internet connection and the RUT950 is connected over cellular network (tested with two different operators)
the OVPN server works just fine if i connect with a mobile phone or a laptop thats provided internet access through the RUT950 (this tells me that the cellular provider does not block traffic).
When i connect with the RUT950 client the connection is established and the dynamic routes are visible, but if i then test to access any page or internal resource on the network nothing can be reached. i can ping the RUT950 from the client but not any iternet sites etc, tracert wont give me anything either.
I react upon the log stating inactivity after being connected one minute and to me it looks like it´s not able to reestablish the connection,
Mon Jan 8 17:20:02 2024 daemon.notice openvpn(OVPNMTVE)[29249]: Initialization Sequence Completed
Mon Jan 8 17:21:03 2024 daemon.notice openvpn(OVPNMTVE)[29249]: [UniFi_OpenVPN_Server] Inactivity timeout (–ping-restart), restarting
Mon Jan 8 17:21:03 2024 daemon.notice openvpn(OVPNMTVE)[29249]: SIGUSR1[soft,ping-restart] received, process restarting
Mon Jan 8 17:21:03 2024 daemon.notice openvpn(OVPNMTVE)[29249]: Restart pause, 5 second(s)
Mon Jan 8 17:21:08 2024 daemon.warn openvpn(OVPNMTVE)[29249]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mon Jan 8 17:21:08 2024 daemon.notice openvpn(OVPNMTVE)[29249]: Outgoing Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Mon Jan 8 17:21:08 2024 daemon.notice openvpn(OVPNMTVE)[29249]: Incoming Control Channel Authentication: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Mon Jan 8 17:21:08 2024 daemon.notice openvpn(OVPNMTVE)[29249]: TCP/UDP: Preserving recently used remote address: [AF_INET]158.xxx.xxx.xxx:1195
Mon Jan 8 17:21:08 2024 daemon.notice openvpn(OVPNMTVE)[29249]: Socket Buffers: R=[131072->131072] S=[16384->16384]
Mon Jan 8 17:21:08 2024 daemon.notice openvpn(OVPNMTVE)[29249]: Attempting to establish TCP connection with [AF_INET]158.xxx.xxx.xxx:1195 [nonblock]
Mon Jan 8 17:23:08 2024 daemon.err openvpn(OVPNMTVE)[29249]: TCP: connect to [AF_INET]158.xxx.xxx.xxx:1195 failed: Operation timed out
Do you have any ideas?
Thanks in advance /Tobias
