ODT500 OTD5_R_00.07.15.2 Kills ESIM configuration
After update from OTD5_R_00.07.15.1 to OTD5_R_00.07.15.2 the eSIm configuration was empty and communication was down.
Lucky after reapplying OTD5_R_00.07.15.1 everything seems to be working again.
Could you please clarify—do you mean that the eSIM profile and configuration was erased after updating to firmware version 7.15.2, or was it a different issue?
Also, did you perform the update with “Keep settings” enabled, or not?
Yes correct SIM profile and configuration was erased after updating to firmware version 7.15.2 ,
And keep settings was switched on
Did you try to reconfigure the eSIM while using firmware version 7.15.2, or did you downgrade to 7.15.1 without attempting to reconfigure?
