O2 and RUTX50 not working
Hi community.
I’m using the 5g Router RUTX50 in Germany. With telekom everything is working fine.
I’ve to change to o2 ( unlimited contract)
The connection can be established. As soon as requests coming I’m loosing the connection: Latest greatest Firmware.
Auto APN and Manual APN: The same.
The o2 card in a simple tp-link router is working like a charm …
Any idea ? Thanks for the help in advance !
Mon Sep 2 18:21:30 2024 kern.info Mobile data connected (internal modem)
Mon Sep 2 18:21:30 2024 kern.info Joined 5G-NSA network (internal modem)
Mon Sep 2 18:21:30 2024 kern.info Connected to o2 - de operator (internal modem)
Mon Sep 2 18:21:31 2024 user.notice firewall: Reloading firewall due to ifup of mob1s1a1_4 (qmimux0)
Mon Sep 2 18:21:33 2024 daemon.info dnsmasq[2865]: read /etc/hosts - 12 names
Mon Sep 2 18:21:33 2024 daemon.info dnsmasq[2865]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Mon Sep 2 18:21:33 2024 daemon.info dnsmasq-dhcp[2865]: read /etc/ethers - 0 addresses
Mon Sep 2 18:21:45 2024 daemon.warn dnsmasq[2865]: Maximum number of concurrent DNS queries reached (max: 150)
Mon Sep 2 18:21:50 2024 daemon.notice netifd: mob1s1a1 (11840): Request timed out
Mon Sep 2 18:21:50 2024 daemon.notice netifd: mob1s1a1 (11840): Mobile connection lost!
Mon Sep 2 18:21:50 2024 daemon.notice netifd: Interface ‘mob1s1a1’ has lost the connection
Mon Sep 2 18:21:50 2024 daemon.notice netifd: Network device ‘wwan0’ link is down
Mon Sep 2 18:21:50 2024 daemon.notice netifd: mob1s1a1 (12977): Stopping network mob1s1a1
Mon Sep 2 18:21:50 2024 daemon.notice netifd: Interface ‘mob1s1a1_6’ is now down
Mon Sep 2 18:21:50 2024 daemon.notice netifd: Interface ‘mob1s1a1_6’ has link connectivity loss
Mon Sep 2 18:21:50 2024 daemon.warn dnsmasq[2865]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Mon Sep 2 18:21:50 2024 daemon.notice netifd: mob1s1a1 (12977): Stopping network on /dev/cdc-wdm0!
Mon Sep 2 18:21:50 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --stop-network 0xFFFFFFFF --autoconnect
Mon Sep 2 18:21:50 2024 daemon.notice netifd: Network device ‘qmimux0’ link is down
Mon Sep 2 18:21:50 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity loss
Mon Sep 2 18:21:50 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is disabled
Mon Sep 2 18:21:50 2024 daemon.notice netifd: mob1s1a1 (12977): Command failed: Permission denied
Mon Sep 2 18:21:50 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Mon Sep 2 18:21:50 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Mon Sep 2 18:21:50 2024 daemon.notice netifd: mob1s1a1_4 (11824): udhcpc: SIOCGIFINDEX: No such device
Mon Sep 2 18:21:50 2024 daemon.notice netifd: mob1s1a1_4 (11824): udhcpc: received SIGTERM
Mon Sep 2 18:21:50 2024 daemon.notice netifd: mob1s1a1_4 (11824): udhcpc: unicasting a release of 10.240.132.140 to 10.240.132.141
Mon Sep 2 18:21:50 2024 daemon.notice netifd: mob1s1a1_4 (11824): udhcpc: sending release
Mon Sep 2 18:21:50 2024 daemon.notice netifd: mob1s1a1_4 (11824): udhcpc: can’t bind to interface qmimux0: No such device
Mon Sep 2 18:21:50 2024 daemon.notice netifd: mob1s1a1_4 (11824): udhcpc: bindtodevice: No such device
Mon Sep 2 18:21:50 2024 daemon.notice netifd: mob1s1a1_4 (11824): udhcpc: entering released state
Mon Sep 2 18:21:51 2024 daemon.notice netifd: mob1s1a1_4 (11824): Command failed: Permission denied
Mon Sep 2 18:21:51 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now down
Mon Sep 2 18:21:51 2024 daemon.notice netifd: mob1s1a1 (13127): wwan[13127] Using wwan usb device on bus 2-1
Mon Sep 2 18:21:51 2024 daemon.notice netifd: mob1s1a1 (13127): wwan[13127] Using proto:qmapv5 device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel RG50X
Mon Sep 2 18:21:51 2024 daemon.info dnsmasq[2865]: read /etc/hosts - 12 names
Mon Sep 2 18:21:51 2024 daemon.info dnsmasq[2865]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Mon Sep 2 18:21:51 2024 daemon.info dnsmasq-dhcp[2865]: read /etc/ethers - 0 addresses
Mon Sep 2 18:21:51 2024 kern.info Mobile data disconnected (internal modem)
Mon Sep 2 18:21:53 2024 daemon.info dnsmasq[2865]: read /etc/hosts - 12 names
Mon Sep 2 18:21:53 2024 daemon.info dnsmasq[2865]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Mon Sep 2 18:21:53 2024 daemon.info dnsmasq-dhcp[2865]: read /etc/ethers - 0 addresses
Mon Sep 2 18:21:53 2024 user.notice mobile.sh: Received unknown error(1/5): “Unknown error”
Mon Sep 2 18:21:53 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --release-client-id wds
Mon Sep 2 18:21:53 2024 kern.notice IPv4 connectivity started to fail
Mon Sep 2 18:21:56 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,15 --stop-network 0xFFFFFFFF --autoconnect
Mon Sep 2 18:21:56 2024 kern.notice IPv6 connectivity started to fail
Mon Sep 2 18:22:04 2024 user.notice mobile.sh: Received unknown error(1/5): “Unknown error”
Mon Sep 2 18:22:04 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,15 --release-client-id wds
Mon Sep 2 18:22:05 2024 user.notice qmux: mob1s1a1 teardown successful
Mon Sep 2 18:22:07 2024 daemon.notice netifd: mob1s1a1 (13127): Calculated qmimux ifname: qmimux0
Mon Sep 2 18:22:07 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 10000 --set-autoconnect disabled
Mon Sep 2 18:22:08 2024 daemon.notice netifd: mob1s1a1 (13127): Informing driver of raw-ip for wwan0 …
Mon Sep 2 18:22:08 2024 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wda-set-data-format --qos-format 0 --link-layer-protocol raw-ip --endpoint-type hsusb --endpoint-iface-number 4 --ul-protocol qmapv5 --dl-protocol qmapv5 --ul-max-datagrams 11 --ul-datagram-max-size 8192 --dl-max-datagrams 62 --dl-datagram-max-size 31744 --dl-min-padding 0
Mon Sep 2 18:22:08 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,14 --release-client-id wds --modify-profile 3gpp,1 --profile-name 1 --roaming-disallowed-flag no
Mon Sep 2 18:22:14 2024 kern.notice DNS resolution started to fail
Make sure you’re set to IPv4 only and Auto APN:
Thank you very much! With this configuration it is working …
Immer gern :slight_smile:
Viel Spaß beim Surfen!
Wenn du möchtest, darfst du gerne meinen Beitrag liken und als Lösung markieren.
