NTP Time server interface
How to set intrface where NTP clien try take to time?
Now that clent try take time for wan interface. That are checket the tcpdum message look like that go out only to wan interface.
That NTP time server can be also over VPN tunnel site.
Hi…
Looking at this picture…
What happen, when you force servers and use a tcp/ip address in your LAN network or in your VPN address range?
I don’t have that setting for interface
That should not be required. Just specify the IP address of an NTP server that is within your VPN network and it should go via VPN.
I did not test it but I do have the NTP server on the LAN network and that works fine, without having to set an interface.
I like do VPN tunnel for our NTP server (Own network time). I like that Gateway Is NTP server LAN site and same time is client over VPN tunel our NTP server (Own networ time). But I don’t like do for direct that VPN tunnel got to LAN. Now look to tcpdump try find that our NTP server for wan interface. I don’t have any parameter what I can say got that VPN tunnel take that (Own network time).
Sorry I do not understand what you are writing…
okay… You like to use your own ntp server… No worries… remember… VPN it is part of a route daemon… So… when you adding a internal network ip at servers, the route daemon will send this udp packet to your internal network, if they are in the same range.
VPN at LAN? No… but… nothing it is impossible… again… depends what you have in your network… the VPN build at LAN side… it is a good think to test here at my lab… for customers that still using MPLS or Lan2lan and want to increase the privacy of company.
remember… Route Daemon do a lot of thinks at background… the basics of the RUT??? it is a route device.
and… You can always " force " where the packet need to go, using static route.
