Not access RUT901 WebUI
hello team,
My config is router RUT951 with firmware RUT9M_R_00.07.10_WEBUI.
For a week now I have not been able to access my dashboard. Here is a preview of the issue in video issue video.
You should know that my computers connected to the land work well as well as the internet on the WAN. The only problem is that I can’t access my dashboard. How can fix?
Thank you for reaching out.
Have you tried performing a factory resetting the device? Instructions for this process can be found here.
If the issue persists after the reset, please try accessing the Bootloader menu, then uploading and upgrading the firmware through it. You can find the necessary steps and guidelines for this process here.
Additionally, the latest firmware for RUT951 can be downloaded by following this link.
Thank you for your respond.
I will try the factory reset next week when I am near my router.
However I have two questions :
1- what are the most stable firmwares and which have success for the majority of users of the rut 951 and rut 950 routers? I updated the latest versions and I see that there is a lot of instability on the firmware.
2 - what can cause a sudden change in the router configuration so that I can no longer access my dashboard? yet everything has been working well for a few days.
Thank you
