No traffic over IPSec VPN
IPSec VPN comes up on RUTX11 but no traffic is redirected to the tunnel. What am i missing ? When i ping (test) from the rutx11 device it works fine but ping from lan to vpn is not working. Packet counter on vpn is also on 0 B
Is there a route missing ?
[UPDATE]
When i remove the IPSec VPN and recreate it, it works fine. When i restart the device the system forgot the ‘route’ to the VPN-tunnel so no ping is possible anymore.
Hi Sterknetwerk,
Can you try to enable Dead peer detection? It should be under Connection Settings → Advanced Settings. You could check out more about RUTX11 IPsec configuration HERE.
Let me know if this helps.
