Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.000000] Linux version 5.10.199 (app@runner-ju9hssqs-project-352-concurrent-2) (arm-openwrt-linux-muslgnueabi-gcc (OpenWrt GCC 8.4.0 r16279-5cc0535800) 8.4.0, GNU ld (GNU Binutils) 2.34) #0 SMP Thu Feb 15 05:02:46 2024
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] CPU: div instructions available: patching division code
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] OF: fdt: Machine model: RUTX50
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] Memory policy: Data cache writealloc
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] Zone ranges:
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] Normal [mem 0x0000000080000000-0x000000008fffffff]
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] HighMem empty
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] Movable zone start for each node
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] Early memory node ranges
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000080000000-0x0000000087dfffff]
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000087e00000-0x0000000087ffffff]
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000088000000-0x000000008fffffff]
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000008fffffff]
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 0.000000] On node 0 totalpages: 65536
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 0.000000] Normal zone: 576 pages used for memmap
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 0.000000] Normal zone: 65536 pages, LIFO batch:15
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] percpu: Embedded 15 pages/cpu s30924 r8192 d22324 u61440
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 0.000000] pcpu-alloc: s30924 r8192 d22324 u61440 alloc=15*4096
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 64960
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.000000] Kernel command line: ubi.mtd=rootfs ubi.block=0,1 root=/dev/ubiblock0_1 rootfstype=squashfs console=ttyMSM0,115200n8 rootwait
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] Memory: 247156K/262144K available (6364K kernel code, 613K rwdata, 1616K rodata, 1024K init, 239K bss, 14988K reserved, 0K cma-reserved, 0K highmem)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] rcu: Hierarchical RCU implementation.
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] Tracing variant of Tasks RCU enabled.
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] arch_timer: cp15 timer(s) running at 48.00MHz (virt).
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb11fd3bfb, max_idle_ns: 440795203732 ns
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000008] sched_clock: 56 bits at 48MHz, resolution 20ns, wraps every 4398046511096ns
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000025] Switching to timer-based delay loop, resolution 20ns
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000407] Calibrating delay loop (skipped), value calculated using timer frequency.. 96.00 BogoMIPS (lpj=480000)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000429] CPU: Testing write buffer coherency: ok
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000485] pid_max: default: 32768 minimum: 301
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000660] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.000681] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.002042] qcom_scm: convention: smc legacy
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.003082] Setting up static identity map for 0x80300000 - 0x8030003c
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.003270] rcu: Hierarchical SRCU implementation.
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.003556] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.003931] smp: Bringing up secondary CPUs ...
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.007677] smp: Brought up 1 node, 4 CPUs
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.007704] SMP: Total of 4 processors activated (384.00 BogoMIPS).
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.007714] CPU: All CPU(s) started in SVC mode.
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 0.011936] Duplicate name in mnfinfo, renamed to "name#1"
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.013779] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.013958] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.013988] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.014231] pinctrl core: initialized pinctrl subsystem
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.016130] NET: Registered protocol family 16
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.016549] DMA: preallocated 256 KiB pool for atomic coherent allocations
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.017704] thermal_sys: Registered thermal governor 'step_wise'
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.018203] cpuidle: using governor ladder
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.018264] cpuidle: using governor menu
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.046361] cryptd: max_cpu_qlen set to 1000
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.051089] usbcore: registered new interface driver usbfs
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.051164] usbcore: registered new interface driver hub
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.051226] usbcore: registered new device driver usb
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.051280] pps_core: LinuxPPS API ver. 1 registered
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.051293] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.051322] PTP clock support registered
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.053196] clocksource: Switched to clocksource arch_sys_counter
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.054214] NET: Registered protocol family 2
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.054474] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.055679] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.055740] TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.055781] TCP bind hash table entries: 2048 (order: 2, 16384 bytes, linear)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.055832] TCP: Hash tables configured (established 2048 bind 2048)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.055964] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.056009] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.056316] NET: Registered protocol family 1
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.056367] PCI: CLS 0 bytes, default 64
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.059775] workingset: timestamp_bits=14 max_order=16 bucket_order=2
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.064494] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.064520] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Thu Feb 29 18:20:13 2024 kern.err kernel: [ 0.207963] bam-dma-engine 8e04000.dma: num-channels unspecified in dt
Thu Feb 29 18:20:13 2024 kern.err kernel: [ 0.207992] bam-dma-engine 8e04000.dma: num-ees unspecified in dt
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.208715] tcsr 194b000.tcsr: setting usb hs phy mode select = e700e7
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.208819] tcsr 1953000.ess_tcsr: setting ess interface select = 0
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.208920] tcsr 1949000.tcsr: setting wifi_glb_cfg = 41000000
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.209013] tcsr 1957000.tcsr: setting wifi_noc_memtype_m0_m2 = 2222222
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.209351] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.209969] msm_serial 78af000.serial: msm_serial: detected port #0
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.210015] msm_serial 78af000.serial: uartclk = 1843200
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.210074] 78af000.serial: ttyMSM0 at MMIO 0x78af000 (irq = 33, base_baud = 115200) is a MSM
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.210108] msm_serial: console setup on port #0
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.759361] printk: console [ttyMSM0] enabled
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.764528] msm_serial: driver initialized
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.773612] loop: module loaded
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.774439] shift_io@0 enforce active low on chipselect handle
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.777307] spi_qup 78b5000.spi: IN:block:16, fifo:64, OUT:block:16, fifo:64
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 0.782577] spi-nor spi0.0: found xt25f128b, expected n25q128a11
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.789237] spi-nor spi0.0: xt25f128b (16384 Kbytes)
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.794834] 16 fixed-partitions partitions found on MTD device spi0.0
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.799615] Creating 16 MTD partitions on "spi0.0":
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.805977] 0x000000000000-0x000000040000 : "0:SBL1"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.811296] 0x000000040000-0x000000060000 : "0:MIBIB"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.816520] 0x000000060000-0x000000080000 : "0:BOOTCONFIG"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.821291] 0x000000080000-0x0000000a0000 : "0:BOOTCONFIG1"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.826717] 0x0000000a0000-0x000000100000 : "0:QSEE_1"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.832124] 0x000000100000-0x000000160000 : "0:QSEE"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.837381] 0x000000160000-0x000000170000 : "0:CDT_1"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.842455] 0x000000170000-0x000000180000 : "0:CDT"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.847458] 0x000000180000-0x000000190000 : "0:DDRPARAMS"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.852112] 0x000000190000-0x0000001a0000 : "0:APPSBLENV"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.857732] 0x0000001a0000-0x000000240000 : "0:APPSBL_1"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.863112] 0x000000240000-0x0000002e0000 : "0:APPSBL"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.868505] 0x0000002e0000-0x0000002f0000 : "0:ART"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.873389] 0x0000002f0000-0x000000300000 : "0:CONFIG"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.878183] 0x000000300000-0x000000310000 : "0:CONFIG_RW"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.883388] 0x000000310000-0x0000003a0000 : "0:EVENTSLOG"
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.895062] spi-nand spi0.1: Winbond SPI NAND W25M02GV was found.
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 0.895112] spi-nand spi0.1: 256 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.900756] 2 fixed-partitions partitions found on MTD device spi0.1
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.908362] Creating 2 MTD partitions on "spi0.1":
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 0.914668] 0x000000000000-0x000008000000 : "rootfs_1"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 1.259675] 0x000008000000-0x000010000000 : "rootfs"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 1.403225] random: crng init done
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 1.600430] mtd: setting mtd17 (rootfs) as root device
Thu Feb 29 18:20:13 2024 kern.alert kernel: [ 1.601668] mtdsplit: no squashfs found in "rootfs"
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 1.663636] MNFINFO PROPERTIES:
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 1.663671] mac : 20972717DC63
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 1.665588] name : RUTX5000XXXX
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 1.669406] serial : 6000957876
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 1.672964] hwver : 0202
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 1.676207] branch :
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 1.679214] batch : 0017
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 1.681730] sim_count: 4
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 1.684613] blver : 2.1
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 1.729817] ESS reset ok!
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 1.803932] ESS reset ok!
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 2.556680] i2c /dev entries driver
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 2.558607] sdhci: Secure Digital Host Controller Interface driver
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 2.558986] sdhci: Copyright(c) Pierre Ossman
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 2.565327] sdhci-pltfm: SDHCI platform and OF driver helper
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 2.576287] NET: Registered protocol family 10
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 2.577821] Segment Routing with IPv6
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 2.579731] NET: Registered protocol family 17
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 2.583555] 8021q: 802.1Q VLAN Support v1.8
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 2.587840] Registering SWP/SWPB emulation handler
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 2.603431] gpio-export soc:gpio-export: 4 gpio(s) exported
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 2.603803] ubi0: attaching mtd17
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 5.638903] ubi0: scanning is finished
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 5.678908] ubi0: attached mtd17 (name "rootfs", size 128 MiB)
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 5.679002] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 5.683809] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 5.690554] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 5.697513] ubi0: good PEBs: 1024, bad PEBs: 0, corrupted PEBs: 0
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 5.704246] ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 5.710438] ubi0: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 1865532814
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 5.717623] ubi0: available PEBs: 0, total reserved PEBs: 1024, PEBs reserved for bad PEB handling: 40
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 5.727005] ubi0: background thread "ubi_bgt0d" started, PID 141
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 5.728241] block ubiblock0_1: created from ubi0:1(rootfs)
Thu Feb 29 18:20:13 2024 kern.err kernel: [ 5.743432] UBI error: block: can't add 'rootfs' volume, err=-17
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 5.766343] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 5.767966] Freeing unused kernel memory: 1024K
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 5.783601] Run /sbin/init as init process
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 5.783636] with arguments:
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 5.783644] /sbin/init
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 5.783652] with environment:
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 5.783659] HOME=/
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 5.783667] TERM=linux
Thu Feb 29 18:20:13 2024 user.info kernel: [ 6.590450] init: Console is alive
Thu Feb 29 18:20:13 2024 user.info kernel: [ 6.590857] init: - watchdog -
Thu Feb 29 18:20:13 2024 user.info kernel: [ 10.256674] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 10.426628] genirq: irq_chip msmgpio did not update eff. affinity mask of irq 101
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 10.432991] SCSI subsystem initialized
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.436838] uhci_hcd: USB Universal Host Controller Interface driver
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.821761] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.821940] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.826688] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f665 hci version 0x100 quirks 0x0000000002010010
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.833837] xhci-hcd xhci-hcd.0.auto: irq 102, io mem 0x08a00000
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.843362] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.849378] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.854697] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.862927] hub 1-0:1.0: USB hub found
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.868894] hub 1-0:1.0: 1 port detected
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.873001] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.879995] hub 2-0:1.0: USB hub found
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.884766] hub 2-0:1.0: 1 port detected
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.888757] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.892351] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.898112] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f665 hci version 0x100 quirks 0x0000000002010010
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.905274] xhci-hcd xhci-hcd.1.auto: irq 103, io mem 0x06000000
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.914775] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.920817] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.926139] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.934741] hub 3-0:1.0: USB hub found
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.940333] hub 3-0:1.0: 1 port detected
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.944478] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.948655] hub 4-0:1.0: USB hub found
Thu Feb 29 18:20:13 2024 kern.err kernel: [ 10.957155] hub 4-0:1.0: config failed, hub doesn't have any ports! (err -19)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 10.966053] usbcore: registered new interface driver usb-storage
Thu Feb 29 18:20:13 2024 user.info kernel: [ 10.967352] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Thu Feb 29 18:20:13 2024 user.info kernel: [ 10.975833] init: - preinit -
Thu Feb 29 18:20:13 2024 user.info kernel: [ 13.221677] mount_root: loading kmods from internal overlay
Thu Feb 29 18:20:13 2024 user.info kernel: [ 13.277753] kmodloader: loading kernel modules from //etc/modules-boot.d/*
Thu Feb 29 18:20:13 2024 user.info kernel: [ 13.287590] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 15.335121] UBIFS (ubi0:2): Mounting in unauthenticated mode
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 15.335501] UBIFS (ubi0:2): background thread "ubifs_bgt0_2" started, PID 267
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 15.521663] UBIFS (ubi0:2): recovery needed
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 15.987766] UBIFS (ubi0:2): recovery completed
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 15.988009] UBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name "rootfs_data"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 15.991132] UBIFS (ubi0:2): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 15.999083] UBIFS (ubi0:2): FS size: 99295232 bytes (94 MiB, 782 LEBs), journal size 4952064 bytes (4 MiB, 39 LEBs)
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 16.008967] UBIFS (ubi0:2): reserved for root: 4689958 bytes (4580 KiB)
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 16.019205] UBIFS (ubi0:2): media format: w5/r0 (latest is w5/r0), UUID E5EB491C-84E4-4665-B753-E3BC82FC011C, small LPT model
Thu Feb 29 18:20:13 2024 user.info kernel: [ 16.030533] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
Thu Feb 29 18:20:13 2024 user.info kernel: [ 16.065133] block: extroot: not configured
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 16.065479] UBIFS (ubi0:2): un-mount UBI device 0
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 16.068193] UBIFS (ubi0:2): background thread "ubifs_bgt0_2" stops
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 16.087865] UBIFS (ubi0:2): Mounting in unauthenticated mode
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 16.088491] UBIFS (ubi0:2): background thread "ubifs_bgt0_2" started, PID 268
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 16.522577] UBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name "rootfs_data"
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 16.522690] UBIFS (ubi0:2): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 16.529629] UBIFS (ubi0:2): FS size: 99295232 bytes (94 MiB, 782 LEBs), journal size 4952064 bytes (4 MiB, 39 LEBs)
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 16.539431] UBIFS (ubi0:2): reserved for root: 4689958 bytes (4580 KiB)
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 16.549670] UBIFS (ubi0:2): media format: w5/r0 (latest is w5/r0), UUID E5EB491C-84E4-4665-B753-E3BC82FC011C, small LPT model
Thu Feb 29 18:20:13 2024 user.info kernel: [ 16.579340] mount_root: loading kmods from internal overlay
Thu Feb 29 18:20:13 2024 user.info kernel: [ 16.635836] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
Thu Feb 29 18:20:13 2024 user.info kernel: [ 16.642414] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
Thu Feb 29 18:20:13 2024 user.info kernel: [ 18.421315] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
Thu Feb 29 18:20:13 2024 user.info kernel: [ 18.439030] block: extroot: not configured
Thu Feb 29 18:20:13 2024 user.info kernel: [ 18.448383] mount_root: switching to ubifs overlay
Thu Feb 29 18:20:13 2024 user.warn kernel: [ 18.534319] urandom-seed: Seeding with /etc/urandom.seed
Thu Feb 29 18:20:13 2024 user.warn kernel: [ 20.162206] - preparing events-log partition -
Thu Feb 29 18:20:13 2024 user.warn kernel: [ 20.268896] Unlocking /dev/mtd15 ...
Thu Feb 29 18:20:13 2024 kern.notice kernel: [ 20.381785] jffs2: notice: (281) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
Thu Feb 29 18:20:13 2024 user.info kernel: [ 20.460146] procd: - early -
Thu Feb 29 18:20:13 2024 user.info kernel: [ 20.460701] procd: - watchdog -
Thu Feb 29 18:20:13 2024 user.warn kernel: [ 20.926075] [01-serial-symlink.sh] New device ttyS0 at /devices/platform/serial8250/tty/ttyS0 appeared!
Thu Feb 29 18:20:13 2024 user.warn kernel: [ 21.089303] [01-serial-symlink.sh] New device ttyMSM0 at /devices/platform/soc/78af000.serial/tty/ttyMSM0 appeared!
Thu Feb 29 18:20:13 2024 user.info kernel: [ 21.156718] procd: - watchdog -
Thu Feb 29 18:20:13 2024 user.info kernel: [ 21.167426] procd: - ubus -
Thu Feb 29 18:20:13 2024 user.warn kernel: [ 21.203838] [01-serial-symlink.sh] New device ttyS1 at /devices/platform/serial8250/tty/ttyS1 appeared!
Thu Feb 29 18:20:13 2024 user.info kernel: [ 21.375903] procd: - init -
Thu Feb 29 18:20:13 2024 user.info kernel: [ 23.331505] urngd: v1.0.2 started.
Thu Feb 29 18:20:13 2024 user.info kernel: [ 23.893811] kmodloader: loading kernel modules from /etc/modules.d/*
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 23.943012] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 23.951845] NET: Registered protocol family 15
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 23.954820] Initializing XFRM netlink socket
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 23.957728] tun: Universal TUN/TAP device driver, 1.6
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 23.986517] l2tp_core: L2TP core driver, V2.0
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 23.988247] l2tp_netlink: L2TP netlink interface
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 23.992056] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 23.997475] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.002314] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.022690] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.025932] gre: GRE over IPv4 demultiplexor driver
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.030002] ip_gre: GRE over IPv4 tunneling driver
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.046096] ip6_gre: GRE over IPv6 tunneling driver
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.117806] tlt-gpio: set names for 1000000.pinctrl chip
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.118855] tlt-gpio: set names for 74hc595 chip
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.134438] hid: raw HID events driver (C) Jiri Kosina
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.136045] GACT probability on
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.139873] Mirror/redirect action on
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.150282] u32 classifier
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.150320] input device check on
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.151888] Actions configured
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.179891] fuse: init (API version 7.32)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.200860] PPP generic driver version 2.4.2
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.446394] ess-switch dts node number: 1
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.446573] ess-switch DT exist!
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.449436] switch_access_mode: local bus
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.452709] mac mode = 0x0
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.456717] mac mode1 doesn't exit!
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.459214] mac mode2 doesn't exit!
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.462682] ess-uniphy DT doesn't exist!
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.466146] cannot find port_scheduler_resource node
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.470240] qcom,port_phyinfo DT doesn't exist!
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.475277] mdio DT exist!
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.479470] switchreg_base_addr: 0xc000000
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.482229] switchreg_size: 0x80000
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.486412] ess-psgmii DT exist!
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.489692] current dts led_source_num is 0
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.556566] qca probe malibu phy driver succeeded!
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.597062] Initializing DESS!!
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.597439] Initializing DESS Done!!
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 24.599129] qca-ssdk module init succeeded!
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.607931] usbcore: registered new interface driver usbserial_generic
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.608059] usbserial: USB Serial support registered for generic
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.615121] usbcore: registered new interface driver cypress_reconf
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.619700] usbcore: registered new interface driver cypress_serial
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.625883] usbserial: USB Serial support registered for CY7C65213
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.641566] usbcore: registered new interface driver ark3116
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.641692] usbserial: USB Serial support registered for ark3116
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.648687] usbcore: registered new interface driver belkin_sa
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.652396] usbserial: USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.716194] Bluetooth: Core ver 2.22
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.716379] NET: Registered protocol family 31
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.718868] Bluetooth: HCI device and connection manager initialized
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.723153] Bluetooth: HCI socket layer initialized
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.729651] Bluetooth: L2CAP socket layer initialized
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.734338] Bluetooth: SCO socket layer initialized
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.741293] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.744186] Bluetooth: BNEP filters: protocol multicast
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.749691] Bluetooth: BNEP socket layer initialized
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.763041] usbcore: registered new interface driver btusb
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.765617] usbcore: registered new interface driver cdc_acm
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.767464] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.775228] usbcore: registered new interface driver cdc_wdm
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.782522] usbcore: registered new interface driver ch341
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.787187] usbserial: USB Serial support registered for ch341-uart
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.794242] usbcore: registered new interface driver usb_ch343
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.798358] ch343: USB serial driver for ch342/ch343/ch344/ch347/ch9101/ch9102/ch9103/ch9104, etc.
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.804329] ch343: V1.5 On 2022.12
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.817647] Loading modules backported from Linux version v6.1.24-0-g0102425ac76b
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.817707] Backport generated by backports.git v5.15.92-1-44-gd6ea70fafd36
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.825820] usbcore: registered new interface driver cp210x
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.831003] usbserial: USB Serial support registered for cp210x
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.838975] usbcore: registered new interface driver cypress_m8
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.842441] usbserial: USB Serial support registered for DeLorme Earthmate USB
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.848382] usbserial: USB Serial support registered for HID->COM RS232 Adapter
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.855641] usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.883913] usbcore: registered new interface driver ftdi_sio
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.884030] usbserial: USB Serial support registered for FTDI USB Serial Device
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.890547] Bluetooth: HCI UART driver ver 2.3
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.895799] Bluetooth: HCI UART protocol H4 registered
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.900281] Bluetooth: HCI UART protocol BCSP registered
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.907449] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 24.910893] Bluetooth: HIDP socket layer initialized
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.084150] usbcore: registered new interface driver pl2303
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.084265] usbserial: USB Serial support registered for pl2303
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.093383] PPP MPPE Compression module registered
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.096085] NET: Registered protocol family 24
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.100805] PPTP driver version 0.8.5
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.107288] Bluetooth: RFCOMM TTY layer initialized
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.107483] Bluetooth: RFCOMM socket layer initialized
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.112180] Bluetooth: RFCOMM ver 1.11
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.125257] usbcore: registered new interface driver usblp
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.195650] xt_time: kernel timezone is -0000
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.251556] l2tp_ppp: PPPoL2TP kernel driver, V2.0
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.517553] usbcore: registered new interface driver option
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.517670] usbserial: USB Serial support registered for GSM modem (1-port)
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.527025] usbcore: registered new interface driver qmi_wwan
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.532948] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 25.534899] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 26.704999] ath10k_ahb a000000.wifi: qca4019 hw1.0 target 0x01000000 chip_id 0x003b00ff sub 0000:0000
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 26.705067] ath10k_ahb a000000.wifi: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 26.717994] ath10k_ahb a000000.wifi: firmware ver 10.4-3.53-00050 api 5 features no-p2p,mfp,peer-flow-ctrl,btcoex-param,allows-mesh-bcast,no-ps crc32 de6451a8
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 26.762815] ath10k_ahb a000000.wifi: board_file api 2 bmi_id 0:16 crc32 01911547
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 28.150138] ath10k_ahb a000000.wifi: htt-ver 2.2 wmi-op 6 htt-op 4 cal pre-cal-file max-sta 512 raw 0 hwcrypto 1
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 28.210938] ath: EEPROM regdomain: 0x0
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 28.210954] ath: EEPROM indicates default country code should be used
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 28.210960] ath: doing EEPROM country->regdmn map search
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 28.210970] ath: country maps to regdmn code: 0x3a
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 28.210977] ath: Country alpha2 being used: US
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 28.210983] ath: Regpair used: 0x3a
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 28.803562] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 28.975899] option 2-1:1.0: GSM modem (1-port) converter detected
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 28.976258] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 28.981629] option 2-1:1.1: GSM modem (1-port) converter detected
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 28.988252] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 28.994960] option 2-1:1.2: GSM modem (1-port) converter detected
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 29.001159] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 29.007584] option 2-1:1.3: GSM modem (1-port) converter detected
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 29.013865] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB3
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 29.039948] qmi_wwan 2-1:1.4: cdc-wdm0: USB WDM device
Thu Feb 29 18:20:13 2024 kern.warn kernel: [ 29.040323] QMI_WWAN: extending urb size to 31744
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 29.047213] qmi_wwan 2-1:1.4 wwan0: register 'qmi_wwan' at usb-xhci-hcd.0.auto-1, WWAN/QMI device, 92:8c:e8:15:83:86
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 29.065546] ath10k_ahb a800000.wifi: qca4019 hw1.0 target 0x01000000 chip_id 0x003b00ff sub 0000:0000
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 29.065630] ath10k_ahb a800000.wifi: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 29.078711] ath10k_ahb a800000.wifi: firmware ver 10.4-3.53-00050 api 5 features no-p2p,mfp,peer-flow-ctrl,btcoex-param,allows-mesh-bcast,no-ps crc32 de6451a8
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 29.123003] ath10k_ahb a800000.wifi: board_file api 2 bmi_id 0:17 crc32 01911547
Thu Feb 29 18:20:13 2024 user.warn kernel: [ 29.192078] [01-serial-symlink.sh] New device ttyUSB0 at /devices/platform/soc/8af8800.usb3/8a00000.dwc3/xhci-hcd.0.auto/usb2/2-1/2-1:1.0/ttyUSB0/tty/ttyUSB0 appeared!
Thu Feb 29 18:20:13 2024 user.warn kernel: [ 29.374604] [01-serial-symlink.sh] New device ttyUSB1 at /devices/platform/soc/8af8800.usb3/8a00000.dwc3/xhci-hcd.0.auto/usb2/2-1/2-1:1.1/ttyUSB1/tty/ttyUSB1 appeared!
Thu Feb 29 18:20:13 2024 user.warn kernel: [ 29.555640] [01-serial-symlink.sh] New device ttyUSB2 at /devices/platform/soc/8af8800.usb3/8a00000.dwc3/xhci-hcd.0.auto/usb2/2-1/2-1:1.2/ttyUSB2/tty/ttyUSB2 appeared!
Thu Feb 29 18:20:13 2024 user.warn kernel: [ 29.735649] [01-serial-symlink.sh] New device ttyUSB3 at /devices/platform/soc/8af8800.usb3/8a00000.dwc3/xhci-hcd.0.auto/usb2/2-1/2-1:1.3/ttyUSB3/tty/ttyUSB3 appeared!
Thu Feb 29 18:20:13 2024 kern.info kernel: [ 30.507767] ath10k_ahb a800000.wifi: htt-ver 2.2 wmi-op 6 htt-op 4 cal pre-cal-file max-sta 512 raw 0 hwcrypto 1
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 30.527980] ath: EEPROM regdomain: 0x0
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 30.528000] ath: EEPROM indicates default country code should be used
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 30.528008] ath: doing EEPROM country->regdmn map search
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 30.528023] ath: country maps to regdmn code: 0x3a
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 30.528032] ath: Country alpha2 being used: US
Thu Feb 29 18:20:13 2024 kern.debug kernel: [ 30.528040] ath: Regpair used: 0x3a
Thu Feb 29 18:20:13 2024 user.info kernel: [ 30.533426] kmodloader: done loading kernel modules from /etc/modules.d/*
Thu Feb 29 18:20:14 2024 daemon.notice procd: /etc/rc.d/S06firewall: uci: Entry not found
Thu Feb 29 18:20:14 2024 daemon.notice procd: /etc/rc.d/S06firewall: sh: 1: unknown operand
Thu Feb 29 18:20:14 2024 daemon.notice procd: /etc/rc.d/S06firewall: sh: 0: unknown operand
Thu Feb 29 18:20:14 2024 daemon.notice procd: /etc/rc.d/S06firewall: UCI configuration was not found for HNAT.
Thu Feb 29 18:20:16 2024 user.notice : Added device handler type: bonding
Thu Feb 29 18:20:16 2024 user.notice : Added device handler type: 8021ad
Thu Feb 29 18:20:16 2024 user.notice : Added device handler type: 8021q
Thu Feb 29 18:20:16 2024 user.notice : Added device handler type: macvlan
Thu Feb 29 18:20:16 2024 user.notice : Added device handler type: veth
Thu Feb 29 18:20:16 2024 user.notice : Added device handler type: bridge
Thu Feb 29 18:20:16 2024 user.notice : Added device handler type: Network device
Thu Feb 29 18:20:16 2024 user.notice : Added device handler type: tunnel
Thu Feb 29 18:20:16 2024 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Thu Feb 29 18:20:16 2024 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Thu Feb 29 18:20:17 2024 daemon.info dnsmasq[1734]: Connected to system UBus
Thu Feb 29 18:20:17 2024 daemon.info dnsmasq[1734]: started, version 2.85 cachesize 150
Thu Feb 29 18:20:17 2024 daemon.info dnsmasq[1734]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Thu Feb 29 18:20:17 2024 daemon.info dnsmasq[1734]: UBus support enabled: connected to system bus
Thu Feb 29 18:20:17 2024 daemon.info dnsmasq[1734]: using only locally-known addresses for domain test
Thu Feb 29 18:20:17 2024 daemon.info dnsmasq[1734]: using only locally-known addresses for domain onion
Thu Feb 29 18:20:17 2024 daemon.info dnsmasq[1734]: using only locally-known addresses for domain localhost
Thu Feb 29 18:20:17 2024 daemon.info dnsmasq[1734]: using only locally-known addresses for domain invalid
Thu Feb 29 18:20:17 2024 daemon.info dnsmasq[1734]: using only locally-known addresses for domain bind
Thu Feb 29 18:20:17 2024 daemon.info dnsmasq[1734]: using only locally-known addresses for domain lan
Thu Feb 29 18:20:17 2024 daemon.warn dnsmasq[1734]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Thu Feb 29 18:20:17 2024 daemon.info dnsmasq[1734]: read /etc/hosts - 4 addresses
Thu Feb 29 18:20:17 2024 daemon.info dnsmasq[1734]: read /tmp/hosts/dhcp.cfg01411c - 0 addresses
Thu Feb 29 18:20:19 2024 daemon.info gsmd[1914]: gsmd-ng init
Thu Feb 29 18:20:19 2024 daemon.info gsmd[1914]: gsmd-ng canary build git#b4ee8e767d
Thu Feb 29 18:20:19 2024 daemon.info gsmd[1914]: AT traffic support: yes
Thu Feb 29 18:20:19 2024 daemon.info gsmd[1914]: Baseband feature support: no
Thu Feb 29 18:20:19 2024 daemon.info gsmd[1914]: gsmd-ng running
Thu Feb 29 18:20:19 2024 daemon.notice procd: /etc/rc.d/S13openssl: Generating engines.cnf
Thu Feb 29 18:20:19 2024 daemon.notice procd: /etc/rc.d/S13openssl: Generating providers.cnf
Thu Feb 29 18:20:19 2024 daemon.notice procd: /etc/rc.d/S13openssl: Enabling legacy
Thu Feb 29 18:20:19 2024 daemon.err mobifd: Failed to get information about modems
Thu Feb 29 18:20:19 2024 daemon.notice wpa_supplicant[1789]: Successfully initialized wpa_supplicant
Thu Feb 29 18:20:20 2024 daemon.err urcd: Failed to get modems
Thu Feb 29 18:20:21 2024 kern.info kernel: [ 40.999408] br-lan: port 1(eth0) entered blocking state
Thu Feb 29 18:20:21 2024 kern.info kernel: [ 40.999460] br-lan: port 1(eth0) entered disabled state
Thu Feb 29 18:20:21 2024 daemon.notice netifd: Interface 'lan' is enabled
Thu Feb 29 18:20:21 2024 daemon.notice netifd: Interface 'lan' is setting up now
Thu Feb 29 18:20:21 2024 kern.info kernel: [ 41.004086] device eth0 entered promiscuous mode
Thu Feb 29 18:20:21 2024 daemon.notice netifd: Interface 'lan' is now up
Thu Feb 29 18:20:21 2024 daemon.info dnsmasq[1734]: reading /tmp/resolv.conf.d/resolv.conf.auto
Thu Feb 29 18:20:21 2024 daemon.info dnsmasq[1734]: using only locally-known addresses for domain test
Thu Feb 29 18:20:21 2024 daemon.info dnsmasq[1734]: using only locally-known addresses for domain onion
Thu Feb 29 18:20:21 2024 daemon.info dnsmasq[1734]: using only locally-known addresses for domain localhost
Thu Feb 29 18:20:21 2024 daemon.info dnsmasq[1734]: using only locally-known addresses for domain invalid
Thu Feb 29 18:20:21 2024 daemon.info dnsmasq[1734]: using only locally-known addresses for domain bind
Thu Feb 29 18:20:21 2024 daemon.info dnsmasq[1734]: using only locally-known addresses for domain lan
Thu Feb 29 18:20:21 2024 daemon.info dnsmasq[1734]: using nameserver 1.1.1.1#53
Thu Feb 29 18:20:21 2024 daemon.info dnsmasq[1734]: using nameserver 1.0.1.1#53
Thu Feb 29 18:20:21 2024 daemon.notice netifd: Interface 'loopback' is enabled
Thu Feb 29 18:20:21 2024 daemon.notice netifd: Interface 'loopback' is setting up now
Thu Feb 29 18:20:21 2024 daemon.notice netifd: Interface 'loopback' is now up
Thu Feb 29 18:20:21 2024 daemon.notice netifd: Interface 'wan' is enabled
Thu Feb 29 18:20:21 2024 daemon.notice netifd: Interface 'wan6' is enabled
Thu Feb 29 18:20:21 2024 kern.info kernel: [ 41.136319] ess_edma c080000.edma eth1: Link is Down
Thu Feb 29 18:20:21 2024 daemon.notice netifd: Network device 'eth0' link is up
Thu Feb 29 18:20:21 2024 daemon.notice netifd: Network device 'lo' link is up
Thu Feb 29 18:20:21 2024 daemon.notice netifd: Interface 'loopback' has link connectivity
Thu Feb 29 18:20:21 2024 authpriv.info dropbear[2346]: Not backgrounding
Thu Feb 29 18:20:21 2024 daemon.notice netifd: radio0 (2330): WARNING: Variable 'data' does not exist or is not an array/object
Thu Feb 29 18:20:21 2024 daemon.notice netifd: radio1 (2331): WARNING: Variable 'data' does not exist or is not an array/object
Thu Feb 29 18:20:22 2024 daemon.notice hostapd: Set new config for phy phy0:
Thu Feb 29 18:20:22 2024 kern.info kernel: [ 42.073329] br-lan: port 1(eth0) entered blocking state
Thu Feb 29 18:20:22 2024 kern.info kernel: [ 42.073389] br-lan: port 1(eth0) entered forwarding state
Thu Feb 29 18:20:22 2024 kern.info kernel: [ 42.084830] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Thu Feb 29 18:20:22 2024 daemon.notice netifd: bridge 'br-lan' link is up
Thu Feb 29 18:20:22 2024 daemon.notice netifd: Interface 'lan' has link connectivity
Thu Feb 29 18:20:22 2024 daemon.notice wpa_supplicant[1789]: Set new config for phy phy0
Thu Feb 29 18:20:22 2024 daemon.notice hostapd: Set new config for phy phy1:
Thu Feb 29 18:20:22 2024 daemon.notice wpa_supplicant[1789]: Set new config for phy phy1
Thu Feb 29 18:20:22 2024 kern.warn kernel: [ 42.714622] netlink: 'iw': attribute type 302 has an invalid length.
Thu Feb 29 18:20:22 2024 kern.warn kernel: [ 42.763455] netlink: 'iw': attribute type 302 has an invalid length.
Thu Feb 29 18:20:23 2024 daemon.notice wpa_supplicant[1789]: Set new config for phy phy0
Thu Feb 29 18:20:23 2024 daemon.notice hostapd: Set new config for phy phy0: /var/run/hostapd-phy0.conf
Thu Feb 29 18:20:23 2024 daemon.notice hostapd: Restart interface for phy phy0
Thu Feb 29 18:20:23 2024 daemon.notice wpa_supplicant[1789]: Set new config for phy phy1
Thu Feb 29 18:20:24 2024 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=US ieee80211d=1 hw_mode=g supported_rates=60 90 120 180 240 360 480 540 basic_rates=60 120 240 beacon_int=100 dtim_period=2 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-7935][DSSS_CCK-40] channel=acs_survey interface=wlan0 bssid=20:97:27:17:dc:65 ctrl_interface=/var/run/hostapd ap_isolate=1 bss_load_update_period=60 chan_util_avg_period=600 disassoc_low_ack=1 skip_inactivity_poll=0 preamble=1 wmm_enabled=1 ignore_broadcast_ssid=0 uapsd_advertisement_enabled=1 utf8_ssid=1 multi_ap=0 wpa_passphrase=r7RXe1n2 wpa_psk_file=/etc/hostapd/wlan0.psk auth_algs=1 wpa=2 wpa_pairwise=CCMP ssid=RUT_DC65_2G bridge=br-lan wpa_disable_eapol_key_retries=0 wpa_key_mgmt=WPA-PSK okc=0 disable_pmksa_caching=1 dynamic_vlan=0 vlan_naming=1 vlan_file=/var/run/hostapd-wlan0.vlan config_id=d0eadb71417864
Thu Feb 29 18:20:24 2024 user.info kernel: [ 44.810723] kmodloader: loading kernel modules from /etc/modules-late.d/*
Thu Feb 29 18:20:24 2024 user.info kernel: [ 44.811293] kmodloader: done loading kernel modules from /etc/modules-late.d/*
Thu Feb 29 18:20:24 2024 kern.notice ip_blockd service is enabled, initialized firewall rules
Thu Feb 29 18:20:25 2024 kern.notice Port link state of port CPU/WiFi changed to UP
Thu Feb 29 18:20:25 2024 kern.notice Port speed for port CPU/WiFi changed to 1000 baseT
Thu Feb 29 18:20:25 2024 kern.notice Port link state of port LAN4 changed to UP
Thu Feb 29 18:20:25 2024 kern.notice Port speed for port LAN4 changed to 1000 baseT
Thu Feb 29 18:20:25 2024 daemon.info gsmd[1914]: [ubus_notify_event:299] error: [MODEM_UBUS] Failed to send ubus notify for `2-1 [2c7c:0800]` modem!
Thu Feb 29 18:20:25 2024 kern.info kernel: [ 45.751092] br-lan: port 2(wlan0) entered blocking state
Thu Feb 29 18:20:25 2024 kern.info kernel: [ 45.751151] br-lan: port 2(wlan0) entered disabled state
Thu Feb 29 18:20:25 2024 kern.info kernel: [ 45.756027] device wlan0 entered promiscuous mode
Thu Feb 29 18:20:25 2024 kern.info kernel: [ 45.761028] br-lan: port 2(wlan0) entered blocking state
Thu Feb 29 18:20:25 2024 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Thu Feb 29 18:20:25 2024 kern.info kernel: [ 45.765458] br-lan: port 2(wlan0) entered forwarding state
Thu Feb 29 18:20:25 2024 kern.info kernel: [ 45.779526] br-lan: port 2(wlan0) entered disabled state
Thu Feb 29 18:20:25 2024 daemon.notice hostapd: ACS: Automatic channel selection started, this may take a bit
Thu Feb 29 18:20:25 2024 daemon.notice hostapd: wlan0: interface state COUNTRY_UPDATE->ACS
Thu Feb 29 18:20:25 2024 daemon.notice hostapd: wlan0: ACS-STARTED
Thu Feb 29 18:20:25 2024 daemon.notice hostapd: Set new config for phy phy1: /var/run/hostapd-phy1.conf
Thu Feb 29 18:20:25 2024 daemon.notice hostapd: Restart interface for phy phy1
Thu Feb 29 18:20:26 2024 daemon.info mobifd: [gsm.modem0] Starting modem settings init
Thu Feb 29 18:20:26 2024 daemon.info mobifd: [gsm.modem0] SIM is ready
Thu Feb 29 18:20:26 2024 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=US ieee80211d=1 ieee80211h=1 hw_mode=a beacon_int=100 dtim_period=2 chanlist=36 tx_queue_data2_burst=2.0 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[HT40+][LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-7935][DSSS_CCK-40] ieee80211ac=1 vht_oper_chwidth=1 vht_oper_centr_freq_seg0_idx=42 vht_capab=[RXLDPC][SHORT-GI-80][TX-STBC-2BY1][SU-BEAMFORMER][SU-BEAMFORMEE][MU-BEAMFORMER][MU-BEAMFORMEE][RX-ANTENNA-PATTERN][TX-ANTENNA-PATTERN][RX-STBC-1][SOUNDING-DIMENSION-2][BF-ANTENNA-3][MAX-MPDU-11454][MAX-A-MPDU-LEN-EXP7] channel=36 interface=wlan1 bssid=20:97:27:17:dc:66 ctrl_interface=/var/run/hostapd ap_isolate=1 bss_load_update_period=60 chan_util_avg_period=600 disassoc_low_ack=1 skip_inactivity_poll=0 preamble=1 wmm_enabled=1 ignore_broadcast_ssid=0 uapsd_advertisement_enabled=1 utf8_ssid=1 multi_ap=0 wpa_passphrase=r7RXe1n2 wp
Thu Feb 29 18:20:26 2024 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Thu Feb 29 18:20:26 2024 daemon.info dnsmasq[1734]: exiting on receipt of SIGTERM
Thu Feb 29 18:20:27 2024 cron.err crond[3524]: crond (busybox 1.34.1) started, log level 5
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: Connected to system UBus
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: started, version 2.85 cachesize 150
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: UBus support enabled: connected to system bus
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq-dhcp[3431]: DHCP, IP range 192.168.8.2 -- 192.168.8.249, lease time 12h
Thu Feb 29 18:20:27 2024 kern.info kernel: [ 47.856759] br-lan: port 3(wlan1) entered blocking state
Thu Feb 29 18:20:27 2024 kern.info kernel: [ 47.856816] br-lan: port 3(wlan1) entered disabled state
Thu Feb 29 18:20:27 2024 kern.info kernel: [ 47.861636] device wlan1 entered promiscuous mode
Thu Feb 29 18:20:27 2024 kern.info kernel: [ 47.866792] br-lan: port 3(wlan1) entered blocking state
Thu Feb 29 18:20:27 2024 kern.info kernel: [ 47.871077] br-lan: port 3(wlan1) entered forwarding state
Thu Feb 29 18:20:27 2024 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Thu Feb 29 18:20:27 2024 kern.info kernel: [ 47.877435] br-lan: port 3(wlan1) entered disabled state
Thu Feb 29 18:20:27 2024 daemon.notice hostapd: wlan1: interface state COUNTRY_UPDATE->HT_SCAN
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: using only locally-known addresses for domain test
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: using only locally-known addresses for domain onion
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: using only locally-known addresses for domain localhost
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: using only locally-known addresses for domain invalid
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: using only locally-known addresses for domain bind
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: using only locally-known addresses for domain lan
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: reading /tmp/resolv.conf.d/resolv.conf.auto
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: using nameserver 1.1.1.1#53
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: using nameserver 1.0.1.1#53
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: read /etc/hosts - 4 addresses
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Thu Feb 29 18:20:27 2024 daemon.info dnsmasq[3431]: read /tmp/hosts/dhcp.cfg01411c.3435 - 0 addresses
Thu Feb 29 18:20:28 2024 daemon.info dnsmasq-dhcp[3431]: read /etc/ethers - 0 addresses
Thu Feb 29 18:20:28 2024 daemon.notice netifd: Wireless device 'radio0' is now up
Thu Feb 29 18:20:28 2024 daemon.notice netifd: Wireless device 'radio1' is now up
Thu Feb 29 18:20:28 2024 daemon.info mobifd: [gsm.modem0] Modem settings init completed
Thu Feb 29 18:20:28 2024 daemon.info mobifd: [gsm.modem0] Starting connection setup
Thu Feb 29 18:20:28 2024 daemon.info dnsmasq[3431]: read /etc/hosts - 4 addresses
Thu Feb 29 18:20:28 2024 daemon.info dnsmasq[3431]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Thu Feb 29 18:20:28 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with "15s" of timeout
Thu Feb 29 18:20:28 2024 daemon.info mobifd: [gsm.modem0] Trying to connect to "23430" operator
Thu Feb 29 18:20:28 2024 kern.info kernel: [ 48.589767] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Thu Feb 29 18:20:28 2024 kern.info kernel: [ 48.590115] br-lan: port 3(wlan1) entered blocking state
Thu Feb 29 18:20:28 2024 kern.info kernel: [ 48.595355] br-lan: port 3(wlan1) entered forwarding state
Thu Feb 29 18:20:28 2024 daemon.notice netifd: Network device 'wlan1' link is up
Thu Feb 29 18:20:29 2024 daemon.notice hostapd: wlan1: interface state HT_SCAN->ENABLED
Thu Feb 29 18:20:29 2024 daemon.notice hostapd: wlan1: AP-ENABLED
Thu Feb 29 18:20:29 2024 cron.err crond[4061]: crond (busybox 1.34.1) started, log level 5
Thu Feb 29 18:20:30 2024 daemon.info dnsmasq-dhcp[3431]: DHCPREQUEST(br-lan) 192.168.1.118 00:e0:4c:68:04:c7
Thu Feb 29 18:20:30 2024 daemon.info dnsmasq-dhcp[3431]: DHCPNAK(br-lan) 192.168.1.118 00:e0:4c:68:04:c7 wrong network
Thu Feb 29 18:20:33 2024 daemon.info dnsmasq-dhcp[3431]: DHCPDISCOVER(br-lan) 00:e0:4c:68:04:c7
Thu Feb 29 18:20:33 2024 daemon.info dnsmasq-dhcp[3431]: DHCPOFFER(br-lan) 192.168.8.89 00:e0:4c:68:04:c7
Thu Feb 29 18:20:33 2024 daemon.info dnsmasq-dhcp[3431]: DHCPREQUEST(br-lan) 192.168.8.89 00:e0:4c:68:04:c7
Thu Feb 29 18:20:33 2024 daemon.info dnsmasq-dhcp[3431]: DHCPACK(br-lan) 192.168.8.89 00:e0:4c:68:04:c7 StormIR-Control
Thu Feb 29 18:20:33 2024 kern.info Leased 192.168.8.89 IP address for client 00:e0:4c:68:04:c7 - StormIR-Control in LAN
Thu Feb 29 18:20:35 2024 daemon.notice hostapd: wlan0: ACS-COMPLETED freq=2427 channel=4
Thu Feb 29 18:20:35 2024 kern.info kernel: [ 55.305868] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Thu Feb 29 18:20:35 2024 kern.info kernel: [ 55.306416] br-lan: port 2(wlan0) entered blocking state
Thu Feb 29 18:20:35 2024 kern.info kernel: [ 55.311368] br-lan: port 2(wlan0) entered forwarding state
Thu Feb 29 18:20:35 2024 daemon.notice netifd: Network device 'wlan0' link is up
Thu Feb 29 18:20:35 2024 daemon.notice hostapd: wlan0: interface state ACS->ENABLED
Thu Feb 29 18:20:35 2024 daemon.notice hostapd: wlan0: AP-ENABLED
Thu Feb 29 18:20:37 2024 cron.err crond[5164]: crond (busybox 1.34.1) started, log level 5
Thu Feb 29 18:20:44 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with "30s" of timeout
Thu Feb 29 18:20:44 2024 daemon.info mobifd: [gsm.modem0] Trying to connect to "23430" operator
Thu Feb 29 18:20:45 2024 kern.notice Password auth succeeded for admin on HTTP from 192.168.8.89
Thu Feb 29 18:20:45 2024 daemon.err uhttpd[2157]: vuci: accepted login for admin from 192.168.8.89
Thu Feb 29 18:20:45 2024 daemon.info procd: - init complete -
Thu Feb 29 18:20:46 2024 daemon.info dfota[5677]: Searching for WAN...
Thu Feb 29 18:20:51 2024 kern.notice kernel: vuci configuration has been changed
Thu Feb 29 18:21:14 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with "60s" of timeout
Thu Feb 29 18:21:14 2024 daemon.info mobifd: [gsm.modem0] Trying to connect to "23430" operator
Thu Feb 29 18:21:18 2024 kern.notice kernel: vuci configuration has been changed
Thu Feb 29 18:22:15 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with "180s" of timeout
Thu Feb 29 18:22:15 2024 daemon.info mobifd: [gsm.modem0] Trying to connect to "23430" operator
