No Internet Connection with t-mobile.pl
Hi!
I have a problem with a rut951 which I would like to operate with a SIM card from t-mobile.pl. The router indicates that it has a connection but when I try to open a website nothing happens. I tryed with auto apn and custom apn.
what could be the problem?
Thanks for reaching out!
Can you please go to the device’s CLI and login via root as a username and the password is the same as WebUI. And please run ping 8.8.8.8 command and share the output here.
And also can you please check the zone window. If the LAN → WAN connections seems okay?
I also attached the screenshot below.
Caner
Hi!
Thanks for your help.
Zones are Like this.
Your router has internet connection and there shouldn’t be any issue.
Can you please click edit on your WAN interface and change the PDP type to IPv4 only?
Maybe your devices is getting IPv6 address instead of IPv4.
After you change the configuration please reboot your device.
Please let me know about the result!
Caner
