No gateway on Local device connected to RUT241
My local device does not allow me to put a gateway IP address because of this I am unable to use the VPN on the RUT to establish communication
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 16998.
The issue has been resolved by using TAP on the RMS VPN hub, this way to reach the end device remotely, a gateway wasn’t necessary.
