I have a RUT 300 router with RMS configuration.
In this router I have one device under 192.168.1.108 local IP address.
What I want is to create a VPN so I could access this device on my local computer - MacOS.
This is what I do:
Create a VPN Hub and add myself and this device as “Clients” (attached screenshot)
Add route for this 192.168.1.108 device from my router (attached screenshot)
In Teltonika RMS VPN app I can see this VPN and I enable it. MacOS recognized this and the VPN state is Connected.
Unfortunately I can’t connect to 192.168.1.108 device or even ping it.
I know it’s online, because when I connect to the router via RMS CLI I can ping and telnet it.
Tracerouter from my local computer ends with this result:
krzysztof@MacBook-Pro ~ % traceroute 192.168.1.108
traceroute to 192.168.1.108 (192.168.1.108), 64 hops max, 40 byte packets
1 192.168.255.1 (192.168.255.1) 41.213 ms 41.923 ms 36.108 ms
2 * * *
3 * * *
4 * * *
sorry for late reply.
I’ve tested it on a few devices and now I know how to do it.
Everytime I create a new VPN hub I have to connect to it on my computer and click this “Restart hub” button on MacOS app and then everything works fine.
Thank you all for help!
