I have installed the RUTM11 successfully. All devices can be reached via ZeroTier. The devices in LAN interface are not to be accessed from other device in the same interface.
Ping is ok from CLI and from remote PC (via ZeroTier), but not from other connected device.
Device name RUTM11
Product code RUTM1100XXXX
Firmware version RUTM_R_00.07.15.2
Kernel version 6.6.87
Thank you for any help.
pi@raspi-3:~ $ ping 192.168.1.128
PING 192.168.1.128 (192.168.1.128) 56(84) bytes of data.
From 192.168.1.156 icmp_seq=1 Destination Host Unreachable
From 192.168.1.156 icmp_seq=2 Destination Host Unreachable
admin@RUTM11:~$ ping 192.168.1.128
PING 192.168.1.128 (192.168.1.128): 56 data bytes
64 bytes from 192.168.1.128: seq=0 ttl=128 time=6.676 ms
64 bytes from 192.168.1.128: seq=1 ttl=128 time=101.803 ms
64 bytes from 192.168.1.128: seq=2 ttl=128 time=121.319 ms
64 bytes from 192.168.1.128: seq=3 ttl=128 time=248.836 ms
PS C:\Users\Wolfgang> ping 192.168.1.128
Ping wird ausgeführt für 192.168.1.128 mit 32 Bytes Daten:
Antwort von 192.168.1.128: Bytes=32 Zeit=96ms TTL=127
Antwort von 192.168.1.128: Bytes=32 Zeit=111ms TTL=127
Antwort von 192.168.1.128: Bytes=32 Zeit=121ms TTL=127
Antwort von 192.168.1.128: Bytes=32 Zeit=12ms TTL=127
my RUTM11 is located in my Motor-Home.
at home connected to my home-WLAN to the interfaces wifi1 and wifi2
away from home connected to mob1s1a1
these devices are connected to the router:
Interface Hostname Address connected to
lan iPhone-Womo 192.168.1.241 RUT_2FE6_5G (wireless)
lan shellyplug-s 192.168.1.128 RUT_2FE5_2G (wireless)
lan raspi-3 192.168.1.156 LAN1 (wired)
no static routes are configured
ZeroTier network configuration:
Port: 9993 Bridge to: None Allow managed IP: on
in my ZeroTier Network are 8 members authorized, among others:
I have sent you a form for private communication, please fill in the form, and in ticket ID provide this query ID which is 14488. This form should arrive to your personal email address used to register to this site.
