How can I access nextcloud through RMS? I get everytime to the website of my nextcloud running on my server which my rut200 router is connected to. But I think nextcloud just straight up blocks the ip of the url RMS makes because it uses proxy?? I need to add the ip address/domain to trusted domains in config.php file right? The ip doesn’t work or I just haven’t got it working.
Someone have some advice or experience with this? Total beginner in networking xD
Could you try adding the IP addresses provided in this wiki article (RMS Management section) to the trusted domains in your config.php file for Nextcloud? These IP addresses are used by RMS, and adding them to the trusted list should help resolve the issue you’re experiencing with accessing Nextcloud through RMS.
Feel free to reach out if you need further assistance or have any additional questions.
Those did nothing. Hmmm. What could be the problem xD
So nextcloud says Access from an untrusted domain. Could I test without https and see if it works? I’ve heard that https could be the root of some problems in remote things. So yeah the server is accessed from port 443.
