New package request: softether vpn client
I use softether vpn server (www.softether.org).
Is it possibile to install softether client in a RUT241 ?
Has anyone developed a softether client package ?
Now i use OpenVPN client configured in order to connect to the softether vpn server but it is not stable…
Currently, softether VPN is not directly supported. However, there are some packages available from opkg that can potentially work, but I am not sure. Check for the packages from CLI/SSH:
opkg update
opkg --size list | grep softether
The package will only be available from the CLI and there is no WebUI implementation. I recommend you read about the packages here.
Not sure if this will fit to your device as RUT241 is quite limited on RAM and Flash. If you have a RUTX series device, I suggest you try this on that device.
