today I received my fibre connection in parallel to the LTE 5G. But I am not able to get access
here are the connection details
I am connected from the fibre box with LAN cable to RUTX50 → WAN
can you help me please
Christian
Christian
Some ISPs use tagged VLANs to distribute their services, although it’s not the most customer-friendly option, it’s quite common. If you’re new to networking, I recommend contacting your ISP’s customer support. They should guide you through the setup process.
However, I can provide some guidance that might help:
Navigate to Network → VLAN → Port based and adjust settings as shown in the image below.
Go to Network → VLAN → Interface based and create a new VLAN instance.
Follow the prompts to configure the settings on the subsequent page as indicated in the image below.
Additionally, configure the WAN settings according to the instructions provided in the picture.
Hello Marijus,
many thanks … but where I shall add my USER and PASSWORD … which i blur in my screenshot ?
Cheers,
Christian
This information is only applicable when using PPPoE. Please contact your ISP to learn more about what authentication method they are using, as I am not familiar with it.
