Could you please provide a bit more information to help us understand your setup better:
Which Teltonika device model are you using in your network?
Are VLAN1 and VLAN2 configured on the same device? If so, are they assigned to separate physical ports, or are the VLANs configured across multiple devices?
This information will help us investigate the issue more accurately and provide more targeted assistance.
Absolutely
*) This model is a RUTXR1 (though I also have some RUT951 and RUT955).
*) Vlans are configured on the same device/router. Assigned to different physical interfaces untagged, using port-based.
Once the firewall rules were applied, I disabled the main LAN interface. With this configuration in place, I was able to successfully ping the device with IP 10.10.126.40 connected to VLAN2 from my PC located in VLAN1.
Hi @Vilius
This was exactly the 1:1 setting I was looking for It works perfectly fine!
This article linked was the one I couln’t find in the first place
Regards MJ
