RUTX11 on Firmware 7.10… only mobile connection (no wan cable).
I cannot use mwan3 use [cmd] at all. It appears to be an issue with the interface binding, because the commands work fine when not wrapped by mwan3.
Fails
root@r2-rnhq:~# mwan3 use mob1s1a1 ping -4 -c5 -W1 8.8.8.8
Running 'ping -4 -c5 -W1 8.8.8.8' with DEVICE=wwan0 SRCIP=25.247.27.159 FWMARK=0x3f00 FAMILY=ipv4
PING 8.8.8.8 (8.8.8.8): 56 data bytes
--- 8.8.8.8 ping statistics ---
5 packets transmitted, 0 packets received, 100% packet loss
Succeeds
root@r2-rnhq:~# ping -4 -c5 -W1 -I qmimux0 8.8.8.8
64 bytes from 8.8.8.8: seq=0 ttl=54 time=57.220 ms
64 bytes from 8.8.8.8: seq=1 ttl=54 time=29.580 ms
64 bytes from 8.8.8.8: seq=2 ttl=54 time=29.315 ms
64 bytes from 8.8.8.8: seq=3 ttl=54 time=29.112 ms
64 bytes from 8.8.8.8: seq=4 ttl=54 time=28.943 ms
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 28.943/34.834/57.220 ms
mwan3 status
root@r2-rnhq:~# mwan3 status
Interface status:
interface wan is offline and tracking is not enabled
interface mob1s1a1 is online 00h:09m:33s, uptime 00h:09m:46s and tracking is active
interface mob1s2a1 is offline and tracking is not enabled
Current ipv4 policies:
balance_default:
mob1s1a1 (100%)
mwan_default:
mob1s1a1 (100%)
Current ipv6 policies:
balance_default:
unreachable
mwan_default:
unreachable
Directly connected ipv4 networks:
127.0.0.0/8
224.0.0.0/3
192.168.20.0/24
172.16.40.0/24
192.168.138.0/24
25.247.27.159
192.168.191.0/24
Directly connected ipv6 networks:
fe80::/64
fd7a:115c:a1e0::6e01:3c34
2604:fb61:2120:1d56:f1e7:949d:407c:4a5d
Active ipv4 user rules:
179 12075 - mwan_default all -- * * 0.0.0.0/0 0.0.0.0/0
Active ipv6 user rules:
