Multicast on RMS
Hei , can somebody tell me how i can turn on multicast from wan to RMS ??
Hi Mateusz1990,
Can you explain your requirement more? We do have an option in RMS VPN called WAN forwarding where you will be able to access devices that is on the same WAN as your Teltonika device.
You can also check out this link for RMS VPN configuration.
Let me know if this helps.
Thx for info . I use rms hub form connection with bulding where i have 25 units . That units use multicast and port 3671 . When i connect direct to network with out rms i can reach all units in program . When i use rms i cant do that and i have to setup manualy ip adress for units to connect . My question is if i can change soemthing in router to got all units in my program across RMS .
