Hi
This is the answer I received regarding the server address that needs to be opened in the firewall to update the modem.
I wanted to know if there are other addresses? Because according to my test, the router does not always go to this address
The device uses hostname rut.teltonika.lt for checking the updates. Port 5000 is used to initiate a connection with the FOTA server and check if update for the modem or the firmware is available.
Hope this helps!
I would guess that the server that provides information about the available firmwares is rut.teltonika.lt and all the actual firmware files are hosted on AWS buckets as you can clearly see from your screenshot. So in order to download the firmwares you would need to open a lot of AWS addresses.
