Modem is unreachable after update to 07.06.16
I have made update to latest firmware 07.06.16, on my RUT950 and now i have a red zone on top where say “modem is unreachable”. I dont use the modem and there is no SIM card in sim tray, but i dont think the sim is the problem.
If i run in console the command: lsusb, i dont see any line containing :9008.
Also, i try a some instructions to recover modem and still the same problem:
root@IOT:~# opkg update
Downloading http://opkg.teltonika-networks.com/afc0a8689fd9d4d239f5332e585c1efe784478f38e25946e9749f4f6803dcbbf/Packages.gz
Updated list of available packages in /var/opkg-lists/tlt_packages
Downloading http://opkg.teltonika-networks.com/afc0a8689fd9d4d239f5332e585c1efe784478f38e25946e9749f4f6803dcbbf/Packages.sig
Signature check passed.
root@IOT:~# opkg list | grep -e modem_updater
modem_updater - 5.2 - Modem firmware update tool by Teltonika
root@IOT:~# opkg install modem_updater
Package modem_updater (5.2) installed in root is up to date.
root@IOT:~# modem_updater -g
Command failed: Not found
Modem List:
Please advise.
router is not in warraty
the problem persist even if i put different SIM cards in tray
Can you post output of all 3 commands:
lsusb
ubus call gsm.modem0 info
dmesg | grep modem
Unfortunately, if there is no 9008 when executing lsusb, it means that the modem is no longer recoverable. The only suggestion in this case would be to send your device for repair. Please contact your reseller for assistance.
root@IOT:~# lsusb
Bus 001 Device 001: ID 1d6b:0002
root@IOT:~# ubus call gsm.modem0 info
root@IOT:~# dmesg | grep modem
[   13.186791] Executing do_power_modem preinit_main ...
[   13.261943] Unable to retrieve modem usb info (No error information)
[   13.268825] Unable to retrieve modem timing info (I/O error), using defaults...
[   20.714802] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[   22.610822] usbserial: USB Serial support registered for GSM modem (1-port)
please tell me that it can be fixed :frowning:
Unfortunately i have this router bought from internet on second hand. It was working then…
You think its a physical problem? Can i try a botloader rewrite?
@themsk Sadly, according to the output of your commands, the modem hardware looks to be faulty.
I haven’t opened one in a while so I can’t remember, but since yours it out of warranty already, it doesn’t hurt to open it and inspect if you can find any loose connections. I don’t know if the modem module is separate or soldered to the main PCB.
I recommend contacting the person or vendor from whom you purchased the router, as a repair is needed in this situation. Unfortunately, there are no alternative recovery options for the device.
Please note that the warranty for these devices lasts 2 years. If the device is no longer under warranty, it may be recommended to consider disposal.
ok. thank you guys. i think i will keep it and use it whitout gsm failover :sleepy:
