Modem Firmware Update guide for TRB501 RG520NEBDC
hey @Vilius . i filled the form and submitted. whats next? thnx!
I have sent you further instructions via email, please check your inbox and inform me if you received an email.
All the best,
thnx. got it and replied.
Hi Teltonika,
The guide here shares A02 as the latest available, but Quectel has A03/A04/A05 out, and I see RUTM52 units running A04. Is there a reason A02 is the only version released for the TRB501? Given the issues several of us are seeing on A02, would it be possible to get a newer build to test?
Related question: what does the OCPU suffix in RG520NEBDCR03A02M4G_OCPU_02.200.00.000 mean here? As I understand it, OCPU stands for OpenCPU — a mode where custom application code runs directly on the modem module itself. What is that used for in the TRB501, and why is it needed? And does it mean this is a Teltonika-built image rather than a stock Quectel one, so TRB501 units will never track Quectel’s own firmware fixes, with every modem-level fix having to be re-integrated by Teltonika first?
Asking because the TRB501 has been on the market for about a year now, and it’s rather disconcerting that a product positioned as industrial still has open stability issues at this point.
Please have a look at the answer provided here: TRB501 - Bridge/Passthrough Mode Broken + Modem Crashes on T-Mobile 5G SA (FW 7.19.4 → 7.21) - #20 by Matas
It explains the different versioning between OCPU firmware, if you have any other questions please let me know.
Thank you for the clarification.
So if I understand correctly, there is no newer Quectel OCPU firmware available for this module - which means the issues are not likely to be resolved by a modem firmware update any time soon, and any fix would have to come from the RutOS side.
Hi, i can t have access to the download.
Is it possible to publish it again ?
Alexandre
I also cannot download the file (“Page not found”). Could you please update the link as we have a client that is having to reboot the device every couple of hours.
Peter
Hello @AlexB and @Peter-Tresami,
Apologies for the delayed response and any inconvenience caused.
We have generated a new download link for the modem firmware. You can download the firmware using the link below:
https://share.teltonika.lt/index.php/s/a7kHCGDSB
I hope this helps. If you encounter any issues accessing the link or have any further questions, please let us know.
P.
Hello Povilas,
Thank you. This looks like a new version, the package published for the TRB501 until now was RG520NEBDCR03A02M4G_OCPU_02.200.00.000, which is what my device is currently running.
Could you share what changed in A03, and in which cases it is recommended to install it?
Csaba
I’m following this post with interest…Let us know if we can upgrade safely to A03.
Thanks @Povilas, however the device became unusable and was RMA’d.
Hi @Povilas , can you provide a new link for the latest modem firmware?
Hi, I am having issues with the modem too.
My version is RG520NEBDCR03A01M4G_OCPU_02.200.00.000.
Can you provide the link for the latest modem firmware to me too? Thanks
Hello everyone,
Please accept our apologies for the inconvenience and any misunderstanding.
The previously shared firmware file was deliberately removed because that version had not yet undergone all the necessary testing.
You can find the modem firmware version that has completed the required testing and is ready for use at the link below:
We apologize again for any inconvenience this may have caused and appreciate your understanding.
Hope this helps! If you have any further questions, please don’t hesitate to let us know.
P.
TRB501_R_00.07.24.7 - modem update failed after factory defaults - daemon.err uhttpd[11609]: rm: can’t remove ‘/tmp/modem_update-RG520NEBDCR03A02M4G_OCPU_02.200.02.200/CONTROL’: Permission denied - current one is RG520NEBDCR03A02M4G_OCPU_02.200.00.000
