thank you for your effort and help. Here are my extended tests and also at the end I factory resetted the device. I am afraid to say that I think this device is not able to handle our requirements.
FYI, I had to edit my APN from vodafon.de to vodafon,de becauase the forum detects this as links and two links are my maximum.
#####18_10_2023#####
changing to 4G VoLTE off logread outputs again and modem goes to this. After i try to send the the modem is dead again and no sms came
Wed Oct 18 10:37:15 2023 kern.info kernel: simcard configuration has been changed
Wed Oct 18 10:37:16 2023 daemon.info mobifd: Service reload initiated
Wed Oct 18 10:37:16 2023 daemon.err mobifd: [gsm.modem0] Failed to get usbnet mode
Wed Oct 18 10:37:21 2023 daemon.info mobifd: [gsm.modem0] SMS storage: sm
Wed Oct 18 10:37:21 2023 daemon.info mobifd: [gsm.modem0] VoLTE was succesfully set
Wed Oct 18 10:37:21 2023 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with 15 seconds of timeout
Wed Oct 18 10:37:26 2023 daemon.info mobifd: [gsm.modem0] Connected to operator ‘vodafone,de’
Wed Oct 18 10:37:26 2023 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Wed Oct 18 10:37:26 2023 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “vodafone,de”
Wed Oct 18 10:37:26 2023 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “44212”, cell ID: “10255886”, technology: “E-UTRAN”
Wed Oct 18 10:37:26 2023 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “44212”, cell ID: “10255886”, technology: “E-UTRAN”
Wed Oct 18 10:37:26 2023 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “44212”, cell ID: “10255886”, technology: “E-UTRAN”
Wed Oct 18 10:37:26 2023 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “100.101.236.35”
Wed Oct 18 10:37:26 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Wed Oct 18 10:37:26 2023 daemon.notice netifd: mob1s1a1 (31053): Starting network mob1s1a1 using APN: web,vodafone,de
Wed Oct 18 10:37:26 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 30000 --set-client-id wds,1 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag yes --auth-type none --apn web,vodafone,de --pdp-type ip
Wed Oct 18 10:37:26 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 30000 --get-client-id wds
Wed Oct 18 10:37:26 2023 daemon.notice netifd: mob1s1a1 (31053): 1
Wed Oct 18 10:37:26 2023 daemon.notice netifd: mob1s1a1 (31053): cid4: 1
Wed Oct 18 10:37:26 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 30000 --set-ip-family ipv4 --set-client-id wds,1
Wed Oct 18 10:37:26 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 30000 --set-client-id wds,1 --start-network --apn web,vodafone,de --profile 1 --auth-type none --username --password
Wed Oct 18 10:37:26 2023 daemon.notice netifd: mob1s1a1 (31053): pdh4: -2027593920
Wed Oct 18 10:37:26 2023 daemon.notice netifd: mob1s1a1 (31053): -2027593920
Wed Oct 18 10:37:26 2023 daemon.notice netifd: mob1s1a1 (31053): Setting up rmnet0
Wed Oct 18 10:37:26 2023 daemon.notice netifd: mob1s1a1 (31053): Setting MTU: 1500 on rmnet0
Wed Oct 18 10:37:26 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now up
Wed Oct 18 10:37:26 2023 daemon.notice netifd: Network device ‘rmnet0’ link is up
Wed Oct 18 10:37:27 2023 daemon.notice netifd: mob1s1a1 (31053): Setting up rmnet0 V4 DCHP
Wed Oct 18 10:37:27 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is enabled
Wed Oct 18 10:37:27 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity
Wed Oct 18 10:37:27 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is setting up now
Wed Oct 18 10:37:27 2023 daemon.notice netifd: mob1s1a1_4 (31219): udhcpc: started, v1.34.1
Wed Oct 18 10:37:27 2023 daemon.notice netifd: mob1s1a1_4 (31219): udhcpc: broadcasting discover
Wed Oct 18 10:37:27 2023 daemon.notice netifd: mob1s1a1_4 (31219): udhcpc: broadcasting select for 100.101.236.35, server 100.101.236.36
Wed Oct 18 10:37:27 2023 daemon.notice netifd: mob1s1a1_4 (31219): udhcpc: lease of 100.101.236.35 obtained from 100.101.236.36, lease time 7200
Wed Oct 18 10:37:27 2023 user.notice firewall: Reloading firewall due to ifup of mob1s1a1 (rmnet0)
Wed Oct 18 10:37:27 2023 daemon.info mobifd: Auto APN is disabled on “mob1s1a1”. Skipping Ping To DNS functionality
Wed Oct 18 10:37:27 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now up
Wed Oct 18 10:37:27 2023 daemon.info dnsmasq[6550]: reading /tmp/resolv.conf.d/resolv.conf.auto
Wed Oct 18 10:37:27 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain test
Wed Oct 18 10:37:27 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain onion
Wed Oct 18 10:37:27 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain localhost
Wed Oct 18 10:37:27 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain invalid
Wed Oct 18 10:37:27 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain bind
Wed Oct 18 10:37:27 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain lan
Wed Oct 18 10:37:27 2023 daemon.info dnsmasq[6550]: using nameserver 10.1.1.1#53
Wed Oct 18 10:37:27 2023 daemon.info dnsmasq[6550]: using nameserver 139.7.30.125#53
Wed Oct 18 10:37:27 2023 daemon.info dnsmasq[6550]: using nameserver 139.7.30.126#53
Wed Oct 18 10:37:27 2023 daemon.emerg quota_limit: Set up nftables quota limit on rmnet0 (mob1s1a1)
Wed Oct 18 10:37:28 2023 daemon.info dnsmasq[6550]: read /etc/hosts - 4 addresses
Wed Oct 18 10:37:28 2023 daemon.info dnsmasq[6550]: read /tmp/hosts/dhcp.cfg01411c - 0 addresses
Wed Oct 18 10:37:29 2023 kern.info Mobile data connected (internal modem)
Wed Oct 18 10:37:29 2023 kern.info Joined LTE network (internal modem)
Wed Oct 18 10:37:29 2023 kern.info Connected to vodafone,de operator (internal modem)
Wed Oct 18 10:37:29 2023 user.notice firewall: Reloading firewall due to ifup of mob1s1a1_4 (rmnet0)
Wed Oct 18 10:37:30 2023 daemon.info dnsmasq[6550]: read /etc/hosts - 4 addresses
Wed Oct 18 10:37:30 2023 daemon.info dnsmasq[6550]: read /tmp/hosts/dhcp.cfg01411c - 0 addresses
Wed Oct 18 10:37:30 2023 kern.info Mobile data connected (internal modem)
Wed Oct 18 10:37:30 2023 kern.info Joined LTE network (internal modem)
Wed Oct 18 10:37:30 2023 kern.info Connected to vodafone,de operator (internal modem)
Wed Oct 18 10:37:34 2023 daemon.info procd: Instance ntpclient::instance1 pid 10639 not stopped on SIGTERM, sending SIGKILL instead
Internal modem -76 dBm
Data connection
Connected
State
Registered, home; vodafone,de; 4G (LTE)
Sim card info
Inserted (SIM 1)
Bytes received / sent
1006.8 KB / 72.6 MB
after sms send attempt
Internal modem - dBm
Data connection
Connected
State
N/A; N/A; N/A
Sim card info
N/A (SIM 1)
1006.8 KB / 72.6 MB
Meanwhile logread does not ouput anything…
when I switch to 4G VoLTE on after it cought itself again
Internal modem
-76 dBm
Data connection
Connected
State
Registered, home; vodafone,de; 4G (LTE); VoLTE
Sim card info
Inserted (SIM 1)
1006.5 KB / 72.6 MB
after sms sending(not succesfull), same old. Logread -f no output, only when i change sim configs…
Internal modem
- dBm
Data connection
Connected
State
N/A; N/A; N/A
Sim card info
N/A (SIM 1)
1006.5 KB / 72.6 MB
switching to Auto, VoLTE Auto:
root@IBNDJU05:~# logread -f
Wed Oct 18 12:00:58 2023 kern.info kernel: simcard configuration has been changed
Wed Oct 18 12:00:59 2023 daemon.info mobifd: Service reload initiated
Wed Oct 18 12:00:59 2023 daemon.info mobifd: [gsm.modem0] Config reload initiated
Wed Oct 18 12:00:59 2023 daemon.err mobifd: [gsm.modem0] Failed to get usbnet mode
Wed Oct 18 12:01:00 2023 daemon.notice netifd: mob1s1a1 (12956): Stopping network mob1s1a1
Wed Oct 18 12:01:00 2023 daemon.notice netifd: mob1s1a1 (12956): Stopping network on /dev/cdc-wdm0!
Wed Oct 18 12:01:00 2023 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,1 --stop-network 0xFFFFFFFF --autoconnect
Wed Oct 18 12:01:00 2023 daemon.notice netifd: mob1s1a1 (12956): Releasing client-id 1 on /dev/cdc-wdm0
Wed Oct 18 12:01:00 2023 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,1 --release-client-id wds
Wed Oct 18 12:01:00 2023 daemon.notice netifd: mob1s1a1 (12956): Command failed: Not found
Wed Oct 18 12:01:00 2023 daemon.notice netifd: mob1s1a1_4 (3727): udhcpc: received SIGTERM
Wed Oct 18 12:01:00 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now down
Wed Oct 18 12:01:00 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity loss
Wed Oct 18 12:01:00 2023 daemon.info dnsmasq[6550]: reading /tmp/resolv.conf.d/resolv.conf.auto
Wed Oct 18 12:01:00 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain test
Wed Oct 18 12:01:00 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain onion
Wed Oct 18 12:01:00 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain localhost
Wed Oct 18 12:01:00 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain invalid
Wed Oct 18 12:01:00 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain bind
Wed Oct 18 12:01:00 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain lan
Wed Oct 18 12:01:00 2023 daemon.info dnsmasq[6550]: using nameserver 10.1.1.1#53
Wed Oct 18 12:01:00 2023 daemon.notice netifd: mob1s1a1 (12956): Command failed: Permission denied
Wed Oct 18 12:01:00 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Wed Oct 18 12:01:01 2023 daemon.info dnsmasq[6550]: read /etc/hosts - 4 addresses
Wed Oct 18 12:01:01 2023 daemon.info dnsmasq[6550]: read /tmp/hosts/dhcp.cfg01411c - 0 addresses
Wed Oct 18 12:01:01 2023 kern.info Mobile data disconnected (internal modem)
Wed Oct 18 12:01:04 2023 daemon.info mobifd: [gsm.modem0] SMS storage: sm
Wed Oct 18 12:01:05 2023 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with 15 seconds of timeout
Wed Oct 18 12:01:05 2023 daemon.info mobifd: [gsm.modem0] Connected to operator ‘vodafone,de’
Wed Oct 18 12:01:05 2023 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Wed Oct 18 12:01:05 2023 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “vodafone,de”
Wed Oct 18 12:01:05 2023 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “44212”, cell ID: “10255886”, technology: “E-UTRAN”
Wed Oct 18 12:01:05 2023 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “44212”, cell ID: “10255886”, technology: “E-UTRAN”
Wed Oct 18 12:01:05 2023 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “44212”, cell ID: “10255886”, technology: “E-UTRAN”
Wed Oct 18 12:01:05 2023 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “100.70.230.20”
Wed Oct 18 12:01:05 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Wed Oct 18 12:01:06 2023 daemon.notice netifd: mob1s1a1 (13357): Starting network mob1s1a1 using APN: web,vodafone,de
Wed Oct 18 12:01:06 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 30000 --set-client-id wds,1 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag yes --auth-type none --apn web,vodafone,de --pdp-type ip
Wed Oct 18 12:01:06 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 30000 --get-client-id wds
Wed Oct 18 12:01:06 2023 daemon.notice netifd: mob1s1a1 (13357): 1
Wed Oct 18 12:01:06 2023 daemon.notice netifd: mob1s1a1 (13357): cid4: 1
Wed Oct 18 12:01:06 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 30000 --set-ip-family ipv4 --set-client-id wds,1
Wed Oct 18 12:01:06 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 30000 --set-client-id wds,1 --start-network --apn web,vodafone,de --profile 1 --auth-type none --username --password
Wed Oct 18 12:01:06 2023 daemon.notice netifd: mob1s1a1 (13357): pdh4: -2027140784
Wed Oct 18 12:01:06 2023 daemon.notice netifd: mob1s1a1 (13357): -2027140784
Wed Oct 18 12:01:06 2023 daemon.notice netifd: mob1s1a1 (13357): Setting up rmnet0
Wed Oct 18 12:01:06 2023 daemon.notice netifd: mob1s1a1 (13357): Setting MTU: 1500 on rmnet0
Wed Oct 18 12:01:06 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now up
Wed Oct 18 12:01:06 2023 daemon.notice netifd: Network device ‘rmnet0’ link is up
Wed Oct 18 12:01:06 2023 daemon.notice netifd: mob1s1a1 (13357): Setting up rmnet0 V4 DCHP
Wed Oct 18 12:01:06 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is enabled
Wed Oct 18 12:01:06 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity
Wed Oct 18 12:01:06 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is setting up now
Wed Oct 18 12:01:06 2023 daemon.notice netifd: mob1s1a1_4 (13526): udhcpc: started, v1.34.1
Wed Oct 18 12:01:06 2023 daemon.notice netifd: mob1s1a1_4 (13526): udhcpc: broadcasting discover
Wed Oct 18 12:01:06 2023 daemon.notice netifd: mob1s1a1_4 (13526): udhcpc: broadcasting select for 100.70.230.20, server 100.70.230.21
Wed Oct 18 12:01:06 2023 daemon.notice netifd: mob1s1a1_4 (13526): udhcpc: lease of 100.70.230.20 obtained from 100.70.230.21, lease time 7200
Wed Oct 18 12:01:06 2023 user.notice firewall: Reloading firewall due to ifup of mob1s1a1 (rmnet0)
Wed Oct 18 12:01:06 2023 daemon.info mobifd: Auto APN is disabled on “mob1s1a1”. Skipping Ping To DNS functionality
Wed Oct 18 12:01:06 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now up
Wed Oct 18 12:01:06 2023 daemon.info dnsmasq[6550]: reading /tmp/resolv.conf.d/resolv.conf.auto
Wed Oct 18 12:01:06 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain test
Wed Oct 18 12:01:06 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain onion
Wed Oct 18 12:01:06 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain localhost
Wed Oct 18 12:01:06 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain invalid
Wed Oct 18 12:01:06 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain bind
Wed Oct 18 12:01:06 2023 daemon.info dnsmasq[6550]: using only locally-known addresses for domain lan
Wed Oct 18 12:01:06 2023 daemon.info dnsmasq[6550]: using nameserver 10.1.1.1#53
Wed Oct 18 12:01:06 2023 daemon.info dnsmasq[6550]: using nameserver 139.7.30.125#53
Wed Oct 18 12:01:06 2023 daemon.info dnsmasq[6550]: using nameserver 139.7.30.126#53
Wed Oct 18 12:01:07 2023 daemon.emerg quota_limit: Set up nftables quota limit on rmnet0 (mob1s1a1)
Wed Oct 18 12:01:08 2023 daemon.info dnsmasq[6550]: read /etc/hosts - 4 addresses
Wed Oct 18 12:01:08 2023 daemon.info dnsmasq[6550]: read /tmp/hosts/dhcp.cfg01411c - 0 addresses
Wed Oct 18 12:01:08 2023 kern.info Mobile data connected (internal modem)
Wed Oct 18 12:01:08 2023 kern.info Joined LTE network (internal modem)
Wed Oct 18 12:01:08 2023 kern.info Connected to vodafone,de operator (internal modem)
Wed Oct 18 12:01:08 2023 user.notice firewall: Reloading firewall due to ifup of mob1s1a1_4 (rmnet0)
Wed Oct 18 12:01:09 2023 daemon.info dnsmasq[6550]: read /etc/hosts - 4 addresses
Wed Oct 18 12:01:09 2023 daemon.info dnsmasq[6550]: read /tmp/hosts/dhcp.cfg01411c - 0 addresses
Wed Oct 18 12:01:09 2023 kern.info Mobile data connected (internal modem)
Wed Oct 18 12:01:09 2023 kern.info Joined LTE network (internal modem)
Wed Oct 18 12:01:09 2023 kern.info Connected to vodafone,de operator (internal modem)
Wed Oct 18 12:01:13 2023 daemon.info procd: Instance ntpclient::instance1 pid 4473 not stopped on SIGTERM, sending SIGKILL instead
Internal modem
-75 dBm
Data connection
Connected
State
Sim card info
Inserted (SIM 1)
1004.1 KB / 72.6 MB
sms wasnt send again, no further logread output
modem like this again:
Internal modem
- dBm
Data connection
Connected
State
N/A; N/A; N/A
Sim card info
N/A (SIM 1)
1004.1 KB / 72.6 MB
#####20_10_2023 Further testing######
Today, sending messages up to less then 160 characters still works like a charm, sending bigger like 3 sms maxed out it gets slow, the modem disconnects (not good).
I talked to my boss about the current situation: The sms we need to send are about 600->1000+ characters, so about 5-10 sms per alert, it seems this system is just not capable of that.
I reset the device to its default and tested, the same problems, as you can see below, I tested with many characters, I recieved most of them, but some did not make it, which is absolutely unacceptable in our use case.
At the end I tried to send a small sms “gsmctl -S -s “015735277405 -----””, nothing special, but this is where the modem broke down completely, just like when I started this topic → error message: [gsmctl_send_sms:20] Error: ERROR: Failed to parse response
The device went back to all N/A for many minutes. And I did not recieve the message…
Other sim same problem.
I am reaching the point where this is not a bug, but the device is simply not capable of this kind of load, we purchased this business solution in order to get a reliable system to notify us (mostly at night) when there is an important monitoring alert,
also we wish the whole alert can be sent in that sms, no matter if it is 3 sms long or up to 10 sms (one sms 160 characters). Is there a way to make this work with this device or do we need something else?
The device needs to be reliable and able to send bigger notfications from our Zabbix, if that is not the case this device is not useable for us I am afraid.
root@TRB140:~# gsmctl -S -s "015735277405 --------------------------------------------------------------------------------------------------------
---------------------------------------------------11"
SMS sent: 3
---------------------------------------------------11----------------------------------
^C
^C
---------------------------------------------------11---------------------------------"
SMS sent: 4
root@TRB140:~# gsmctl -S -s "015735277405 -------------------------------------------------------------------------------------------------------------------------------
------------------------------------------------------------------------------------------------------------^C
-------------------------------------------------------------------------------------------------------------------------------------------------------11----------------
-----------------1
SMS sent: 4
----------------2"
SMS sent: 4
root@TRB140:~# --------------------------------------------------------------------------------------------------------------------------------------
-ash: --------------------------------------------------------------------------------------------------------------------------------------: not found
root@TRB140:~# ----------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------11-
------------------------------------------------------------------------------1111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111
111111111111111111
-ash: --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------11-------------------------------------------------------------------------------1111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111: Filename too long
root@TRB140:~# gsmctl -S -s “015735277405 -----”
[gsmctl_send_sms:20] error: ERROR: Failed to parse response
