ModbusTCP to MQTT datastring
I am using a RUT241
With ModbusTCP Client I am reading some Modbus registers from a PLC, this goes OK.
I am sending this data to a MQTT broker with Data to Server, this goes also OK.
My question is that all values start with the word “data” and I want: or the ModbusRegister name + value or only the value..
Here is an example of the received string.
Date : {“EcoPlus”:[{“data”:“108.873917”},{“data”:“7425111”},{“data”:“128”},{“data”:“0.040438”},{“data”:“1.000000”},{“data”:“1.000000”},{“data”:“15.820300”},{“data”:“0”},{“data”:“0”},{“data”:“2”},{“data”:“19636”}]}
Is this a configuration setting in the RUT241?
Maurits
There’s is no simple option to edit this directly, so you would have to opt for one of these 2 options:
  1. Either check whether the received data format is configurable from your MQTT broker.
  2. Use a custom LUA Script in the Data to server, however, this will require some programming knowledge.
Thank you for your reply.
It doesn’t matter any more, I am writing a vb.net program and with Newtonsoft.Json.Linq I get all values in one array, without the register name or “Data”.
Works well for me.
