Hi There, i use RUT906 for taking data modbus rtu in Modbus Serial Client. After completing the modbus settings and the data is read with the “Test” facility, I want to send the data via MQTT via Data to Server. However, when we want to send data, every time we move to Modbus, MQTT does not receive any data, while when we select “Base” the data is sent to MQTT but not the data we want.
To assist you further, could you please share a screenshot of the device logs taken at the moment when the data is being sent to the server? This will help determine whether any errors are occurring during transmission. It would also be helpful if you could include screenshots of your Data to Server configuration.
Please make sure the screenshots do not contain any personal or sensitive information - such as public IP addresses, email addresses, or other identifiable data - as this is a public forum.
Once I have this information, I’ll be able to investigate the issue in more detail.
