I am evaluating TRB256 for a deployment as a Modbus Gateway.
I have a configuration with Modbus TCP over serial Gateway. The device is TRB256 (TRB2M_R_00.07.10.2), serial is RS485. I’m testing with ModbusPoll over TCP/IP.
The connection works well if I use a single client (ModbusPoll).
When I start a second instance of ModbusPoll on my PC and connect to the gateway, all connections are dropped. The gateway does not respond until I manually disconnect and reconnect.
Does the gateway support only one client? Is there something I can configure?
