MODBUS Data Sources don't work
I have checked this topic MODBUS TCP Server - Data Sources documentation missing and this Wiki section RUT956 Modbus - Teltonika Networks Wiki but I can’t make it work.
Could you provide a complete working example?
Thanks in advance.
I had it operational up till the latest version on my RUTx50. Since the upgrade to 7.24.6 it seems that the addressing of the data has changed. The documentation still says what I had configured but all the tests fail. So something goes wrong with the registers or addresses of the data sources.
The last version is RUT9M_R_00.07.24.3_WEBUI.bin. Could you please specify the last working version ?
Thank you for reaching out and apologies for the delayed response.
To help narrow this down, could you please provide the following information:
  1. The current firmware version installed on your device.
  2. A topology of your setup (what is reading the Modbus data and how it’s connected to the router).
  3. Screenshots or a detailed description of your Modbus configuration, including the Data Sources. Please blur any sensitive information.
  4. Could you explain in more detail what behavior you observe when the Data Sources don’t work?
Once we have this information, we’ll be happy to look into it further.
Martyna
RUT9M_R_00.07.24.3, model RUT956
  1. A topology of your setup (what is reading the Modbus data and how it’s connected to the router).
The easiest setup, the router reads itself to obtain just one variable: uptime
  1. Screenshots or a detailed description of your Modbus configuration, including the Data Sources. Please blur any sensitive information.
MODBUS TCP server:
MODBUS TCP client:
After some requests, the client becomes “down” and is not longer requesting:
uptime:
uptime_1025: this request has never worked
  1. Could you explain in more detail what behavior you observe when the Data Sources don’t work?
If you disable reads on “Data sources” it works again:
uptime:
uptime_1025:
Thanks in advance.
For what it is worth mine is working without intervention. It came back after about 24 hrs. I traced it back to a communication issue between the modem and the router. Because only data on the modem was failing, the rest tested normal.
Hello @Linux-RISC,
Could you please make sure that this Data Source is enabled and that the selected source value corresponds to your uptime request. The register type and permissions should also match the intended data mapping.
For testing purposes, I would suggest the following approach:
  1. First, enable the custom register block and configure its starting register as 1025, with a register count of at least 2.
  2. Enable the uptime Data Source and make sure it references the corresponding Modbus TCP Client request.
  3. Temporarily disable the uptime_1025 request in the Modbus TCP Client configuration.
  4. Check whether the Modbus TCP Client remains operational and whether the uptime request continues to return valid results.
  5. Once the Data Source is working, re-enable the uptime_1025 request and check whether you can successfully retrieve the mapped value.
Additionally, could you please provide a screenshot of the complete Data Source configuration window? I would like to verify the selected register value, permissions and data type.
We look forward to your response.
P.
I can’t enable custom register block and data source at the same time:
To avoid confusions, could you please provide a minimal working example?
