Mobile network loose connection
Hello team,
I’m looking for a script that verifies if the mobile network loses connection or goes down, so that it restarts the router.
Watchdog it’s no effective because sometime i’m lagging and can result in a false positive.
Best regards
This functionality is already implemented in our routers. It is called “Ping Reboot” and can be found in the WebUI under System → Maintenance → Auto Reboot.
Hello Marijus,
Thanks for your replay, like i say, watchdog it’s not effective because sometime i’m lagging and can result in a false positive.
Best regards
You can adjust the ping reboot settings to suit your needs. Specifically, you can increase the number of failed pings required before the system reboots by changing the “Interval count” setting.
