Getting this error here after updating the modem FW on an RUTX11. Can anyone provide some insight here?
I am on RUTX_R_00.07.07.1 and the modem FW is EG06ELAR04A07M4G
It seems like your device is trying to connect to a network it’s not allowed to access. This could be because it’s out of range, your SIM card isn’t compatible, or there’s a restriction on your account.
Here’s what you can do to troubleshoot:
Check Network Coverage: Make sure you’re in an area where your carrier’s network coverage is available.
Restart Your Device: Sometimes, simply restarting your device can resolve temporary network issues.
Check SIM Card: Ensure that your SIM card is properly inserted and compatible with your device and carrier.
Check Carrier Settings: Make sure your device’s network settings are correctly configured for your carrier. You may need to update your device’s network settings or contact your carrier for assistance.
Account Status: Verify that there are no issues with your account, such as unpaid bills or restrictions.
Contact Your Carrier: If you’re still experiencing issues, get in touch with your mobile carrier for further assistance. They can help troubleshoot and identify any specific issues related to your account or network.
Think I figured it out. The unit I was testing is an international unit, so I suspect the modem is not compatible with NA sim cards.
Yes, that’s a common issue. Always ensure that the device is intended for the region where it will be deployed.
