Working until Dec 2023 the mobile connection suddenly stopped.
Back at the location today I found this msg in the logs “Mobile data disconnected (internal modem)”
The SIM is active and working and looking in the system log it seems a connection with the mobile network is made but no public IP number was retrieved.
Any suggestion on how to solve this problem is appreciated.
Wed Mar 6 16:39:07 2024 daemon.info unhandler[2209]: gsm send: AT+CFUN?
Wed Mar 6 16:39:07 2024 daemon.info unhandler[2209]: gsm get: +CFUN: 1
Wed Mar 6 16:39:07 2024 daemon.info unhandler[2209]: gsm send: AT+CFUN=4
Wed Mar 6 16:39:07 2024 daemon.info unhandler[2209]: gsm get: OK
Wed Mar 6 16:39:07 2024 daemon.info unhandler[2209]: gsm send: AT+QICSGPEH=1
Wed Mar 6 16:39:07 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CREG: 0’
Wed Mar 6 16:39:07 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CGREG: 0’
Wed Mar 6 16:39:07 2024 daemon.info unhandler[2209]: gsm get: +QICSGPEH: 1,"","","",0
Wed Mar 6 16:39:07 2024 daemon.info unhandler[2209]: gsm send: AT+QICSGPEH=1,1,“airtelnet.es”,“vodafone”,“vodafone”,1
Wed Mar 6 16:39:07 2024 daemon.info unhandler[2209]: gsm get: +CFUN: 4
Wed Mar 6 16:39:07 2024 daemon.info unhandler[2209]: gsm send: AT+CFUN=1
Wed Mar 6 16:39:09 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+QIND: SMS DONE’
Wed Mar 6 16:39:09 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CREG: 2’
Wed Mar 6 16:39:09 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CGREG: 2’
Wed Mar 6 16:39:09 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CREG: 1,“0221”,“AABD308”,7’
Wed Mar 6 16:39:09 2024 daemon.info unhandler[2209]: gsm get: OK
Wed Mar 6 16:39:09 2024 daemon.info unhandler[2209]: 60 s left till new connection attempt.
Wed Mar 6 16:39:09 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CGREG: 1,“0221”,“AABD308”,7’
Wed Mar 6 16:39:09 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘OK’
Wed Mar 6 16:39:11 2024 daemon.info unhandler[2209]: gsm send: AT+CGPADDR=1
Wed Mar 6 16:39:11 2024 daemon.info unhandler[2209]: gsm get: +CGPADDR: 1,"172.19.206.216"
Wed Mar 6 16:39:12 2024 daemon.info unhandler[2209]: Creating 1-1 modem lock file!
Wed Mar 6 16:39:12 2024 daemon.info unhandler[2209]: Realoding network
Wed Mar 6 16:39:12 2024 daemon.info unhandler[2209]: Upping |mob1s1a1| interface
Wed Mar 6 16:39:12 2024 user.err ddns-scripts[14248]: myddns: BusyBox nslookup error: 1
Wed Mar 6 16:39:13 2024 daemon.notice netifd: mob1s1a1 (14492): Stopping network mob1s1a1
Wed Mar 6 16:39:13 2024 daemon.notice netifd: mob1s1a1 (14492): Stopping network on /dev/cdc-wdm0!
Wed Mar 6 16:39:13 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,9 --stop-network 0xFFFFFFFF --autoconnect
Wed Mar 6 16:39:19 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CREG: 1,“0221”,“A88B202”,7’
Wed Mar 6 16:39:19 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CGREG: 1,“0221”,“A88B202”,7’
Wed Mar 6 16:39:22 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Wed Mar 6 16:39:22 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Wed Mar 6 16:39:22 2024 daemon.notice netifd: mob1s1a1 (14559): wwan[14559] Using wwan usb device on bus 1-1
Wed Mar 6 16:39:24 2024 user.err ddns-scripts[14248]: myddns: BusyBox nslookup error: 1
Wed Mar 6 16:39:25 2024 daemon.notice netifd: mob1s1a1 (14559): wwan[14559] Using proto:qmi_wwan device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel EC25
Wed Mar 6 16:39:25 2024 user.notice root: Looking /tmp/mobileon_1-1 flag
Wed Mar 6 16:39:25 2024 user.notice root: Modem is ready!
Wed Mar 6 16:39:26 2024 user.warn ddns-scripts[14248]: myddns: Get registered/public IP for diego66.ddns.net failed - retry 1/0 in 60 seconds
Wed Mar 6 16:39:28 2024 user.warn mwan3-hotplug[14558]: hotplug called on mob1s1a1 before mwan3 has been set up
Wed Mar 6 16:39:30 2024 daemon.notice netifd: mob1s1a1 (14559): Quering active sim position
Wed Mar 6 16:39:33 2024 daemon.info dnsmasq[19433]: read /etc/hosts - 4 addresses
Wed Mar 6 16:39:33 2024 daemon.info dnsmasq[19433]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Wed Mar 6 16:39:34 2024 daemon.info dnsmasq-dhcp[19433]: read /etc/ethers - 0 addresses
Wed Mar 6 16:39:35 2024 kern.info Mobile data disconnected (internal modem)
Wed Mar 6 16:39:38 2024 user.notice ddns-scripts[14248]: myddns: pid 14248 terminated by sigterm at 2024-03-06 16:39
Wed Mar 6 16:39:42 2024 user.notice ddns-scripts[15182]: myddns: pid 15182 started at 2024-03-06 16:39
Wed Mar 6 16:39:54 2024 daemon.info unhandler[2209]: Connection failed. Another attempt after 60 seconds
Wed Mar 6 16:39:56 2024 user.err ddns-scripts[15182]: myddns: BusyBox nslookup error: 1
Wed Mar 6 16:40:07 2024 user.err ddns-scripts[15182]: myddns: BusyBox nslookup error: 1
Wed Mar 6 16:40:07 2024 user.warn ddns-scripts[15182]: myddns: Get registered/public IP for diego66.ddns.net failed - retry 1/0 in 60 seconds
The line you provided indicates a failure to register for diego66.ddns.net:
This is the first place to check. Verify if the hostname (diego66.ddns.net) hasn’t expired. Also, try connecting without using it to ensure that DDNS is not the root cause of the issue.
Marijus
Thanks for checking!
I’ve switched off the ddns feature but unfortunately the result is the same: mobile data disconnected by internal modem.
(see new log content below)
Thu Mar 7 10:49:52 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Thu Mar 7 10:49:52 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm send: AT+QCFG=“IMS”
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm get: +QCFG: "ims",2,0
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: VoLTE should be off
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm send: AT+CGDCONT?
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm get: +CGDCONT: 1,"IP","","0.0.0.0",1,0,0,0 Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: +CGDCONT: 10,"IP","","0.0.0.0",0,0,0,0 Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: +CGDCONT: 11,"IP","","0.0.0.0",0,0,0,0 Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: +CGDCONT: 12,"IP","","0.0.0.0",0,0,0,0 Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: +CGDCONT: 13,"IP","","0.0.0.0",0,0,0,0 Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: +CGDCONT: 14,"IP","","0.0.0.0",0,0,0,0 Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: +CGDCONT: 15,"IP","","0.0.0.0",0,0,0,0 Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: +CGDCONT: 16,"IP","","0.0.0.0",0,0,0,0 Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: +CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0 Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: +CGDCONT: 3,"IPV4V6","SOS","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1 Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: +CGDCONT: 9,"IP","","0.0.0.0",0,0,0,0
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: PDP Type MATCH
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm send: AT+QICSGP=1
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm get: +QICSGP: 1,"","","",0
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm send: AT+CFUN?
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm get: +CFUN: 1
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm send: AT+CFUN=4
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm get: OK
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm send: AT+QICSGPEH=1
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm get: +QICSGPEH: 1,"","","",0
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm send: AT+QICSGPEH=1,1,“airtelnet.es”,“vodafone”,“vodafone”,1
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm get: +CFUN: 4
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: gsm send: AT+CFUN=1
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CREG: 0’
Thu Mar 7 10:49:52 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CGREG: 0’
Thu Mar 7 10:49:54 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+QIND: SMS DONE’
Thu Mar 7 10:49:54 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CREG: 2’
Thu Mar 7 10:49:54 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CGREG: 2’
Thu Mar 7 10:49:54 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CREG: 1,“0221”,“AABD308”,7’
Thu Mar 7 10:49:54 2024 daemon.info unhandler[2209]: gsm get: OK
Thu Mar 7 10:49:54 2024 daemon.info unhandler[2209]: 60 s left till new connection attempt.
Thu Mar 7 10:49:54 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘+CGREG: 1,“0221”,“AABD308”,7’
Thu Mar 7 10:49:54 2024 daemon.info unhandler[2209]: *Unsolicited id: 1-1 | msg: ‘OK’
Thu Mar 7 10:49:56 2024 daemon.info unhandler[2209]: gsm send: AT+CGPADDR=1
Thu Mar 7 10:49:56 2024 daemon.info unhandler[2209]: gsm get: +CGPADDR: 1,"172.19.206.216"
Thu Mar 7 10:49:57 2024 daemon.info unhandler[2209]: Creating 1-1 modem lock file!
Thu Mar 7 10:49:57 2024 daemon.info unhandler[2209]: Realoding network
Can you provide screenshot of Status → Network → Mobile?
Marijus
I have the same problem as this mobile disconnected and on mobile status simcard read but doesnot connect on network
on connection state read unregistered
At the login page I received ‘device is unreachable’. I tried again later but got the same.
I moved the RUT950 from its location and now I have it here at my desk. Power was disconnected and the connected again. And now mobile data is working!
Strange. Of course, I had rebooted the device before but that didn’t help. Is a power off/on different from a reboot?
The issue appears solved for now but might return, at which moment I will open a new ticket.
Reboot and Power Off should have same functionality in terms of resetting device. If issue occurs again feel free to write again.
Marijus
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: Attempt to retrieve IMSI number…
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: IMSI: 214018804211905
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: Checking module revision…
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: Module revision: EC25ECGAR06A08M1G
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: active_sim: |1|
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: pdp: |1|
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: pdp_type: |1|
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: auto_apn: |1|
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: force_apn: |0|
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: mcc: |214|
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: mnc: |018|
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: volte: |0|
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: service_mode:|5|
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: Attempt to fetch APN list…
Fri Mar 8 08:38:26 2024 daemon.info unhandler[2206]: Getting APN list from database
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: APN Fetch is done.
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm send: AT+COPS?
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm get: +COPS: 0,0,"vodafone ES",7
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm send: AT+QCFG=“NWSCANMODEEX”
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm get: +QCFG: "nwscanmodeex",16
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm send: AT+QCFG=“IMS”
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm get: +QCFG: "ims",2,0
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: VoLTE should be off
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm send: AT+CGDCONT?
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm get: +CGDCONT: 1,"IP","airtelnet.es","0.0.0.0",1,0,0,0 Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: +CGDCONT: 10,"IP","","0.0.0.0",0,0,0,0 Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: +CGDCONT: 11,"IP","","0.0.0.0",0,0,0,0 Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: +CGDCONT: 12,"IP","","0.0.0.0",0,0,0,0 Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: +CGDCONT: 13,"IP","","0.0.0.0",0,0,0,0 Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: +CGDCONT: 14,"IP","","0.0.0.0",0,0,0,0 Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: +CGDCONT: 15,"IP","","0.0.0.0",0,0,0,0 Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: +CGDCONT: 16,"IP","","0.0.0.0",0,0,0,0 Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: +CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0 Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: +CGDCONT: 3,"IPV4V6","SOS","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1 Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: +CGDCONT: 9,"IP","","0.0.0.0",0,0,0,0
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: PDP Type MATCH
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm send: AT+QICSGP=1
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm get: +QICSGP: 1,"airtelnet.es","vodafone","vodafone",1
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm send: AT+CFUN?
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm get: +CFUN: 1
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm send: AT+CFUN=4
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm get: OK
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm send: AT+QICSGPEH=1
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: *Unsolicited id: 1-1 | msg: ‘+CREG: 0’
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: *Unsolicited id: 1-1 | msg: ‘+CGREG: 0’
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm get: +QICSGPEH: 1,"airtelnet.es","vodafone","vodafone",1
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm send: AT+QICSGPEH=1,1,“airtelwap.es”,“wap@wap”,“wap125”,1
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm get: +CFUN: 4
Fri Mar 8 08:38:27 2024 daemon.info unhandler[2206]: gsm send: AT+CFUN=1
Fri Mar 8 08:38:28 2024 kern.info kernel: [ 65.170072] eth0: link up (1000Mbps/Full duplex)
Fri Mar 8 08:38:28 2024 kern.info kernel: [ 65.190398] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Fri Mar 8 08:38:28 2024 kern.info kernel: [ 65.208853] br-lan: port 1(eth0.1) entered blocking state
Fri Mar 8 08:38:28 2024 kern.info kernel: [ 65.214409] br-lan: port 1(eth0.1) entered disabled state
Fri Mar 8 08:38:28 2024 kern.info kernel: [ 65.220364] device eth0.1 entered promiscuous mode
Fri Mar 8 08:38:28 2024 kern.info kernel: [ 65.225289] device eth0 entered promiscuous mode
Fri Mar 8 08:38:28 2024 kern.info kernel: [ 65.296196] br-lan: port 1(eth0.1) entered blocking state
Fri Mar 8 08:38:28 2024 kern.info kernel: [ 65.301737] br-lan: port 1(eth0.1) entered forwarding state
Fri Mar 8 08:38:28 2024 daemon.notice netifd: Interface ‘lan’ is enabled
Fri Mar 8 08:38:28 2024 daemon.notice netifd: Interface ‘lan’ is setting up now
Fri Mar 8 08:38:28 2024 daemon.notice netifd: Interface ‘lan’ is now up
Fri Mar 8 08:38:28 2024 daemon.notice netifd: bridge ‘br-lan’ link is up
Fri Mar 8 08:38:28 2024 daemon.notice netifd: Interface ‘lan’ has link connectivity
Fri Mar 8 08:38:28 2024 daemon.notice netifd: Interface ‘loopback’ is enabled
Fri Mar 8 08:38:28 2024 daemon.notice netifd: Interface ‘loopback’ is setting up now
Fri Mar 8 08:38:28 2024 daemon.notice netifd: Interface ‘loopback’ is now up
Fri Mar 8 08:38:28 2024 kern.notice Port link state of port WAN changed to DOWN
Fri Mar 8 08:38:29 2024 daemon.notice netifd: Interface ‘wan’ is enabled
Fri Mar 8 08:38:29 2024 daemon.notice netifd: Interface ‘wan6’ is enabled
Fri Mar 8 08:38:29 2024 daemon.notice netifd: Network device ‘eth0’ link is up
Fri Mar 8 08:38:29 2024 daemon.notice netifd: VLAN ‘eth0.1’ link is up
Fri Mar 8 08:38:29 2024 daemon.notice netifd: Network device ‘lo’ link is up
Fri Mar 8 08:38:29 2024 daemon.notice netifd: Interface ‘loopback’ has link connectivity
Fri Mar 8 08:38:29 2024 daemon.info unhandler[2206]: *Unsolicited id: 1-1 | msg: ‘+QIND: SMS DONE’
Fri Mar 8 08:38:29 2024 daemon.info unhandler[2206]: *Unsolicited id: 1-1 | msg: ‘+CREG: 2’
Fri Mar 8 08:38:29 2024 daemon.info unhandler[2206]: *Unsolicited id: 1-1 | msg: ‘+CGREG: 2’
Fri Mar 8 08:38:29 2024 daemon.info unhandler[2206]: *Unsolicited id: 1-1 | msg: ‘+CREG: 1,“0221”,“AABD308”,7’
Fri Mar 8 08:38:29 2024 daemon.info unhandler[2206]: gsm get: OK
Fri Mar 8 08:38:29 2024 daemon.info unhandler[2206]: 60 s left till new connection attempt.
Fri Mar 8 08:38:29 2024 kern.info kernel: [ 66.176756] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Fri Mar 8 08:38:29 2024 daemon.info unhandler[2206]: *Unsolicited id: 1-1 | msg: ‘+CGREG: 1,“0221”,“AABD308”,7’
Fri Mar 8 08:38:29 2024 daemon.info unhandler[2206]: *Unsolicited id: 1-1 | msg: ‘OK’
Fri Mar 8 08:38:31 2024 daemon.info unhandler[2206]: gsm send: AT+CGPADDR=1
Fri Mar 8 08:38:31 2024 daemon.info unhandler[2206]: gsm get: +CGPADDR: 1,"10.71.50.110"
Fri Mar 8 08:38:31 2024 daemon.info unhandler[2206]: Creating 1-1 modem lock file!
Fri Mar 8 08:38:31 2024 daemon.info unhandler[2206]: Realoding network
Fri Mar 8 08:38:31 2024 daemon.info unhandler[2206]: Upping |mob1s1a1| interface
Fri Mar 8 08:38:31 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Fri Mar 8 08:38:33 2024 daemon.notice netifd: mob1s1a1 (3398): wwan[3398] Using wwan usb device on bus 1-1
Fri Mar 8 08:38:33 2024 user.warn mwan3-hotplug[3243]: hotplug called on lan before mwan3 has been set up
Fri Mar 8 08:38:34 2024 daemon.notice netifd: mob1s1a1 (3398): wwan[3398] Using proto:qmi_wwan device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel EC25
Fri Mar 8 08:38:34 2024 user.notice root: Looking /tmp/mobileon_1-1 flag
Fri Mar 8 08:38:34 2024 user.notice root: Modem is ready!
Fri Mar 8 08:38:36 2024 kern.debug kernel: [ 72.716188] ath: EEPROM regdomain: 0x8348
Fri Mar 8 08:38:36 2024 kern.debug kernel: [ 72.716199] ath: EEPROM indicates we should expect a country code
Fri Mar 8 08:38:36 2024 kern.debug kernel: [ 72.716209] ath: doing EEPROM country->regdmn map search
Fri Mar 8 08:38:36 2024 kern.debug kernel: [ 72.716219] ath: country maps to regdmn code: 0x3a
Fri Mar 8 08:38:36 2024 kern.debug kernel: [ 72.716226] ath: Country alpha2 being used: US
Fri Mar 8 08:38:36 2024 kern.debug kernel: [ 72.716231] ath: Regpair used: 0x3a
Fri Mar 8 08:38:36 2024 kern.debug kernel: [ 72.716239] ath: regdomain 0x8348 dynamically updated by user
Fri Mar 8 08:38:37 2024 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Fri Mar 8 08:38:37 2024 daemon.info unhandler[2206]: *Unsolicited id: 1-1 | msg: ‘+CREG: 1,“0221”,“A88B214”,7’
Fri Mar 8 08:38:37 2024 daemon.info unhandler[2206]: *Unsolicited id: 1-1 | msg: ‘+CGREG: 1,“0221”,“A88B214”,7’
Fri Mar 8 08:38:39 2024 daemon.notice netifd: mob1s1a1 (3398): Quering active sim position
Fri Mar 8 08:38:40 2024 daemon.notice netifd: mob1s1a1 (3398): Using net device: wwan0
Fri Mar 8 08:38:41 2024 daemon.notice hostapd: Configuration file: /var/run/hostapd-phy0.conf (phy wlan0) → new PHY
Fri Mar 8 08:38:41 2024 daemon.notice netifd: mob1s1a1 (3398): Informing driver of raw-ip for wwan0 …
Fri Mar 8 08:38:41 2024 kern.info kernel: [ 77.966066] qmi_wwan 1-1:1.4 wwan0: mode: raw IP
Fri Mar 8 08:38:41 2024 kern.info kernel: [ 78.011607] br-lan: port 2(wlan0) entered blocking state
Fri Mar 8 08:38:41 2024 kern.info kernel: [ 78.017083] br-lan: port 2(wlan0) entered disabled state
Fri Mar 8 08:38:41 2024 kern.info kernel: [ 78.022956] device wlan0 entered promiscuous mode
Fri Mar 8 08:38:41 2024 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Fri Mar 8 08:38:42 2024 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wda-set-data-format --link-layer-protocol raw-ip --ul-protocol disabled --dl-protocol disabled
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq[1816]: exiting on receipt of SIGTERM
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq[4141]: Connected to system UBus
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq[4141]: started, version 2.85 cachesize 150
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq[4141]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq[4141]: UBus support enabled: connected to system bus
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq-dhcp[4141]: DHCP, IP range 192.168.1.100 – 192.168.1.249, lease time 12h
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq[4141]: using only locally-known addresses for domain test
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq[4141]: using only locally-known addresses for domain onion
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq[4141]: using only locally-known addresses for domain localhost
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq[4141]: using only locally-known addresses for domain invalid
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq[4141]: using only locally-known addresses for domain bind
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq[4141]: using only locally-known addresses for domain lan
Fri Mar 8 08:38:42 2024 daemon.warn dnsmasq[4141]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq[4141]: read /etc/hosts - 4 addresses
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq[4141]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Fri Mar 8 08:38:42 2024 daemon.info dnsmasq-dhcp[4141]: read /etc/ethers - 0 addresses
Fri Mar 8 08:38:43 2024 kern.info kernel: [ 79.483755] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Fri Mar 8 08:38:43 2024 kern.info kernel: [ 79.490612] br-lan: port 2(wlan0) entered blocking state
Fri Mar 8 08:38:43 2024 kern.info kernel: [ 79.496096] br-lan: port 2(wlan0) entered forwarding state
Fri Mar 8 08:38:43 2024 daemon.notice hostapd: wlan0: interface state COUNTRY_UPDATE->ENABLED
Fri Mar 8 08:38:43 2024 daemon.notice hostapd: wlan0: AP-ENABLED
Fri Mar 8 08:38:43 2024 daemon.notice netifd: mob1s1a1 (3398): Starting network mob1s1a1 using APN: airtelwap.es
Fri Mar 8 08:38:44 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,7 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --username wap@wap --password wap125 --auth-type pap --apn airtelwap.es --pdp-type ip
Fri Mar 8 08:38:45 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --get-client-id wds
Fri Mar 8 08:38:45 2024 daemon.notice netifd: mob1s1a1 (3398): 7
Fri Mar 8 08:38:45 2024 daemon.notice netifd: mob1s1a1 (3398): cid4: 7
Fri Mar 8 08:38:45 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-ip-family ipv4 --set-client-id wds,“7”
Fri Mar 8 08:38:45 2024 daemon.notice netifd: Wireless device ‘radio0’ is now up
Fri Mar 8 08:38:45 2024 daemon.notice netifd: Network device ‘wlan0’ link is up
Fri Mar 8 08:38:46 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,7 --start-network --apn airtelwap.es --profile 1 --auth-type pap --username wap@wap --password wap125
Fri Mar 8 08:38:46 2024 daemon.notice netifd: mob1s1a1 (3398): pdh4: -511699312
Fri Mar 8 08:38:46 2024 cron.err crond[4428]: crond (busybox 1.34.1) started, log level 5
Fri Mar 8 08:38:46 2024 daemon.notice netifd: mob1s1a1 (3398): -511699312
Fri Mar 8 08:38:47 2024 daemon.notice netifd: mob1s1a1 (3398): Setting up wwan0
Fri Mar 8 08:38:47 2024 daemon.notice netifd: mob1s1a1 (3398): Setting MTU: 1500 on wwan0
Fri Mar 8 08:38:48 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is now up
Fri Mar 8 08:38:48 2024 daemon.notice netifd: Network device ‘wwan0’ link is up
Fri Mar 8 08:38:48 2024 daemon.notice netifd: mob1s1a1 (3398): Setting up wwan0 V4 DCHP
Fri Mar 8 08:38:48 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is enabled
Fri Mar 8 08:38:48 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity
Fri Mar 8 08:38:48 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is setting up now
Fri Mar 8 08:38:49 2024 daemon.notice netifd: mob1s1a1_4 (4660): udhcpc: started, v1.34.1
Fri Mar 8 08:38:49 2024 daemon.info unhandler[2206]: Looking mob1s1a1 IPv4 l3_device
Fri Mar 8 08:38:50 2024 daemon.notice netifd: mob1s1a1_4 (4660): udhcpc: broadcasting discover
Fri Mar 8 08:38:50 2024 daemon.notice netifd: mob1s1a1_4 (4660): udhcpc: broadcasting select for 10.71.50.110, server 10.71.50.109
Fri Mar 8 08:38:50 2024 daemon.notice netifd: mob1s1a1_4 (4660): udhcpc: lease of 10.71.50.110 obtained from 10.71.50.109, lease time 7200
Fri Mar 8 08:38:51 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now up
Fri Mar 8 08:38:51 2024 daemon.info dnsmasq[4141]: reading /tmp/resolv.conf.d/resolv.conf.auto
Fri Mar 8 08:38:51 2024 daemon.info dnsmasq[4141]: using only locally-known addresses for domain test
Fri Mar 8 08:38:51 2024 daemon.info dnsmasq[4141]: using only locally-known addresses for domain onion
Fri Mar 8 08:38:51 2024 daemon.info dnsmasq[4141]: using only locally-known addresses for domain localhost
Fri Mar 8 08:38:51 2024 daemon.info dnsmasq[4141]: using only locally-known addresses for domain invalid
Fri Mar 8 08:38:51 2024 daemon.info dnsmasq[4141]: using only locally-known addresses for domain bind
Fri Mar 8 08:38:51 2024 daemon.info dnsmasq[4141]: using only locally-known addresses for domain lan
Fri Mar 8 08:38:51 2024 daemon.info dnsmasq[4141]: using nameserver 212.166.210.6#53
Fri Mar 8 08:38:51 2024 daemon.info dnsmasq[4141]: using nameserver 212.166.167.72#53
Fri Mar 8 08:38:51 2024 daemon.notice procd: /etc/rc.d/S96led: Command failed: Not found
Fri Mar 8 08:38:51 2024 daemon.info unhandler[2206]: Try to send pings to dest_address: |8.8.8.8| via ipv4: |10.71.50.110|
Fri Mar 8 08:38:52 2024 daemon.notice procd: /etc/rc.d/S96led: setting up led LAN1
Fri Mar 8 08:38:52 2024 daemon.notice procd: /etc/rc.d/S96led: setting up led LAN2
Fri Mar 8 08:38:52 2024 daemon.notice procd: /etc/rc.d/S96led: setting up led LAN3
Fri Mar 8 08:38:52 2024 daemon.info unhandler[2206]: ICMP packet received from 8.8.8.8
Fri Mar 8 08:38:52 2024 daemon.info unhandler[2206]: Server 8.8.8.8 reached
Fri Mar 8 08:38:52 2024 daemon.info unhandler[2206]: Job done
Thanks Marijus!
