Mobile data disconnected (internal modem) in logs
I have a RUTX11 version 07.15.1
After several hours of use my internal modem is disconnected.
In the logs I get this information : Mobile data disconnected (internal modem)
1197 Tue Jul 15 15:42:20 2025 daemon.notice netifd: mob1s1a1_4 (3076): udhcpc: broadcasting renew
1198 Tue Jul 15 15:42:58 2025 daemon.warn dnsmasq[3354]: Maximum number of concurrent DNS queries reached (max: 150)
1199 Tue Jul 15 15:57:21 2025 daemon.notice netifd: mob1s1a1_4 (3076): udhcpc: broadcasting renew
1200 Tue Jul 15 16:02:25 2025 daemon.warn dnsmasq[3354]: Maximum number of concurrent DNS queries reached (max: 150)
1201 Tue Jul 15 16:04:51 2025 daemon.notice netifd: mob1s1a1_4 (3076): udhcpc: broadcasting renew
1202 Tue Jul 15 16:08:36 2025 daemon.notice netifd: mob1s1a1_4 (3076): udhcpc: broadcasting renew
1203 Tue Jul 15 16:10:28 2025 daemon.notice netifd: mob1s1a1_4 (3076): udhcpc: broadcasting renew
1204 Tue Jul 15 16:11:24 2025 daemon.notice netifd: mob1s1a1_4 (3076): udhcpc: broadcasting renew
1205 Tue Jul 15 16:11:53 2025 daemon.notice netifd: mob1s1a1_4 (3076): udhcpc: broadcasting renew
1206 Tue Jul 15 16:11:56 2025 daemon.notice netifd: mob1s1a1_4 (3076): udhcpc: broadcasting renew
1207 Tue Jul 15 16:11:59 2025 daemon.notice netifd: mob1s1a1_4 (3076): udhcpc: broadcasting renew
1208 Tue Jul 15 16:12:02 2025 daemon.notice netifd: mob1s1a1_4 (3076): udhcpc: broadcasting renew
1209 Tue Jul 15 16:12:05 2025 daemon.notice netifd: mob1s1a1_4 (3076): udhcpc: lease lost, entering init state
1210 Tue Jul 15 16:12:05 2025 daemon.notice netifd: Interface ‘mob1s1a1_4’ has lost the connection
1211 Tue Jul 15 16:12:05 2025 daemon.warn dnsmasq[3354]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
1212 Tue Jul 15 16:12:05 2025 daemon.notice netifd: mob1s1a1_4 (3076): udhcpc: broadcasting discover
1213 Tue Jul 15 16:12:06 2025 daemon.info dnsmasq[3354]: read /etc/hosts - 12 names
1214 Tue Jul 15 16:12:06 2025 daemon.info dnsmasq[3354]: read /tmp/hosts/dhcp.cfg01411c - 4 names
1215 Tue Jul 15 16:12:06 2025 daemon.info dnsmasq-dhcp[3354]: read /etc/ethers - 0 addresses
1216 Tue Jul 15 16:12:06 2025 kern.info Mobile data disconnected (internal modem)
1217 Tue Jul 15 16:12:08 2025 daemon.notice netifd: mob1s1a1_4 (3076): udhcpc: broadcasting discover
Thank you for your help.
If you head to the WebUI → Network → WAN and press “Edit” on the mob1s1a1 interface, could you confirm that the PDP type is set to “IPv4”, and the APN settings are properly set as well? Your APN could either be set to auto (if the provider doesn’t request a specific one), or could be set to a manual one.
Additionally, I’d like to suggest upgrading to the very latest, 7.15.4 firmware version, as there were some improvements with the mobile services.
Let me know if this improves the situation,
I confirm you the settings that you have noticed.
I am using private APN so that I configured it in manually state.
Also This morning I had upgraded the firmware but I had again the internal modem has disconnected state after several hours of use.
Regards
Hello, @christophe , one more thing I need you to try are the steps that I’ve provided in this reply: RUT241 udhcp renew doesn't work - #4 by MatasR
I need you to try running these steps, and if you run into any difficulties, don’t heistate to ask for help or guidance.
If the solution does not work, please reply to me and we’ll continue our conversation privately so I can investigate this further.
Thanks MatasR,
I have applied yours steps whithout difficulties.
I wish that this solution will work.
I will inform you the result after tests.
Please let me know if it works! Will be waiting for you.
After testing, we experienced a disconnection on the internal modem.
After restarting the router, the connection is working again.
What information do you need to diagnose?
I’ve sent you a form to fill out so we can continue our conversation in private, to avoid accidentally leaking any sensitive information. In the Ticket ID field, simply enter the thread’s number, which is 14664.
