Mobile Connection and Gps Services
Hello.
I am attempting to use one of your routers (RUT956) on a truck to record and monitor data from the truck. It is working however I do have problems where the mobile connection drops repeatedly. I understand this is most likely due to the router being moved, but is there any way to reduce the effect of this issue. Right now the data is sending every 10 seconds and I get about 1 to 5 readings before it loses connection for anywhere from 1 to 5 minutes. I would understand if this was in remote areas but this is in a area with very good mobile connection. I also have problems where the gps data would lose signal and just never send gps data until the router is rebooted. I don’t know if this router was intended to be used in this way but it would be a great help if I can find a work around to these issues.
I have sent you a form to fill out. Once completed, I will contact you privately. Please use “11766” as the ticket ID.
Thank you for your response. I have filled out the form.
