Mesh RUTX50 and TAP200
I own a RUTX50 and three TAP200 units and would like to set up a Mesh network with a single SSID that operates on both 2.4 GHz and 5 GHz bands.
My questions are as follows:
  • Is it possible to run a Mesh network simultaneously on both frequency bands (2.4 GHz and 5 GHz)?
  • If so, what configuration would you recommend to ensure optimal performance and stability?
  • Are there any known limitations or best practices for this device combination in Mesh mode?
  • Alternatively, would it be better to work with just one frequency? If so, which frequency would you recommend for optimal stability and performance?
Thank you for your support!
JBR
First of all what you mean by mesh?
  • One SSID for all devices (if so just use same ssid and password on all devices and most clients will hop between devices without problems, there is more options like 802.11v, 802.11k, 802.11r but they are not necessary)
  • One device with wired connection and others work as extenders (if this more info bellow)
  1. Currently there is no good way to use both bands because regular 802.11s meshes do not have loop avoidance also because of this only use wired connection on one device
  2. Bands:
    • 2.4ghz - better penetration, more congested, lower speed
    • 5ghz - worse penetration, less congested, higher speed
  3. Frequency/Channel
    • 2.4ghz - use Status > Wireless > Channel Analysis and pick least used one or any of them if you are in less congested place
    • 5ghz - same as 2.4ghz but also would not recommend DFS channels
I forgot to mention that I want to connect each node (TAP 200) via cable to a PoE switch, which in turn is connected to the RUTX50 via cable.
I think that since the TAP200 are already connected via cable, 802.11s (Mesh) is unnecessary.
Would 802.11k & 802.11r then be the optimal solution to enable fast and seamless roaming between the access points?
When you have multiple devices with same SSIDs these additional options can help but they are not necessary. You can enable 802.11v and 802.11k but 802.11r requires bit harder setup then it is worth for regular network
Thanks for your support!
Hello @JBR,
Could you please confirm whether your issue has been resolved, or if you still require assistance?
Everything is working fine!
Thank you for confirming!
